question about eagle rods
Old Nov 8, 2001 | 03:11 PM
PROFILES2000's Avatar
Default question about eagle rods
i recently orderd a set of eagle rods and i have heard from someone that they dont clear the bottom of the stock sleeve and that you have to machine out the bottom to fit.....i need proof like tell me u have a gsr motor with eagle rods and u had no problems
Old Nov 8, 2001 | 04:12 PM
dust's Avatar
Default Re: question about eagle rods (PROFILE GSR)
As far as I know that problem is only on the SOHC engines. I'm sure someone with actual knowledge will post and confirm this.
Old Nov 8, 2001 | 04:26 PM
dustin's Avatar
Default Re: question about eagle rods (dust)
I believe dust is correct, you have to notch the bottom of the sleeves to run eagles OR crowers on the D series blocks. I know several people that have run the GSR eagle rods without notching anything.
Dustin
Old Nov 8, 2001 | 04:42 PM
newspeedR's Avatar
Default Re: question about eagle rods (dustin)
You also have to knotch the girdle if you plan on running a girdle on any Ls block... unless you run the z10 setup...
Other wise... gsr rods will run perfectly in a gsr motor...
Old Nov 8, 2001 | 11:23 PM
Default Re: question about eagle rods (newspeedR)
kool thanks
Laney
Sep 15, 2004 04:42 PM
Soon_2b_evil
Jul 13, 2003 07:51 AM
00 Si
Oct 30, 2001 10:32 AM
SpeedMonkeyRacing
Oct 23, 2001 04:49 PM
