Quaife or ProDrive Spool
Old Oct 16, 2002 | 02:15 PM
kidkutz's Avatar
Default Quaife or ProDrive Spool
Ok...need to know by tomorrow! here's the deal...i have a quaife in my h22a tranny right now. i'm going full race (drag car) so i'm wondering if i should go Prodrive spool rather than my Quaife...what do you guys think?
Old Oct 16, 2002 | 03:34 PM
Speedworks801's Avatar
Default Re: Quaife or ProDrive Spool (kidkutz)
I'd stick with the quaife, they are indestructable and you already have it.
[Modified by Speedworks801, 6:35 PM 10/16/2002]
Old Oct 16, 2002 | 03:38 PM
Gmedalion's Avatar
Between the 2 I would go with Quaife but I would go with Mark Williams or Nitro.
Old Oct 16, 2002 | 03:48 PM
ThePunk's Avatar
Default Re: Quaife or ProDrive Spool (Gmedalion)
Why would you go with anything else for a full drag/ dragstrip ONLY car? SPOOL!
Old Oct 16, 2002 | 05:09 PM
kidkutz's Avatar
Default Re: Quaife or ProDrive Spool (ThePunk)
that's what i was thinking...Quaife is a limited slip...a spool is well...NO SLIP...
i can get the two swapped at no cost...so spool seems to be where i am leaning towards...the only thing appealing about the quaife is that it's warrantied for life
Old Oct 16, 2002 | 06:55 PM
paulzy's Avatar
have you heard about people breaking axles with a spool? Correct me if I'm wrong, but I heard they go all over the place
Old Oct 16, 2002 | 06:57 PM
VaporTrail's Avatar
New User
Default Re: Quaife or ProDrive Spool (paul_vang)
snap an axle, and god hold on! But a spool saves a lot of rotating weight, and gives you full lock, which a quaife never does.
Old Oct 16, 2002 | 07:02 PM
MikeMAN's Avatar
Default Re: Quaife or ProDrive Spool (VaporTrail)
i would say quaife also, since u got it already too
Old Oct 16, 2002 | 07:03 PM
tony1's Avatar
The spool works good on the track, but is a real pain in the *** driving around on 28" slicks through the pits!! We run a quaife and have never had any problems with it. Much easier on the axles too. It must work as we have cut a 1.38 60ft. and a bunch of low 1.4's.
Old Oct 16, 2002 | 07:08 PM
D-Man's Avatar
Default Re: Quaife or ProDrive Spool (tony1)
I wouldnt waste the money on a spool until the quaife you got blows up
Old Oct 16, 2002 | 07:11 PM
Brian_92GSR's Avatar
New User
Default Re: Quaife or ProDrive Spool (D-Man)
That doesn't make any sense. He said he could swap them at no cost, so he wouldn't be wasting any money. And if he stuck with the quaife and it belw up, he'd probably want to utilize the lifetime warranty (one of the reasons he might stick with the quaife).
Old Oct 16, 2002 | 07:21 PM
D-Man's Avatar
Default Re: Quaife or ProDrive Spool (Brian_92GSR)
opps.i didnt read his later post saying that he could swap them at no cost,oh well,maybe this will make better sense to you...why waste the time and extra labor of splitting the tranny to make the swap when there is nothing wrong with the quaife
Old Oct 16, 2002 | 07:53 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
How much do the nitro spools run at $$ price wise.
If I can get the Nitro spool for a good price is it worth it better then quaife.
[Modified by Civicdrgrcr, 11:57 PM 10/16/2002]
Old Oct 16, 2002 | 09:42 PM
TurboITR's Avatar
Default Re: Quaife or ProDrive Spool (Civicdrgrcr)
jonathan if you want a nitro - talk to chris - he should have some extras...
Old Oct 17, 2002 | 02:58 AM
ninesecrx's Avatar
Default Re: Quaife or ProDrive Spool (TurboITR)
Jojo Callos is on 2 seasons with his quaife. I think that a total locking unit is not the way to go anyways. Its all good for a rear drive car, but we have to steer our front wheel drive cars. What happens when you have to steer going down the track? You make one wheel spin faster then the other....makes you loose traction. The torqe biasing of a Quaife also is very helpful in my opion. Also yeah, if you break an axle with a spool....Hold on to your steering wheel cause your going towards the wall. Its funny, a welded diff. is illegal...but a spool isnt? ess. the same thing.
Old Oct 17, 2002 | 03:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Quaife or ProDrive Spool (ninesecrx)
We keept breaking ring gears with the prodrive. After some testing we found that when we bolted the prodrive in the bolts wouldnt go all the way threw. Not a big deal because its thicker for support. But we after breaking so many ring gears we put the quaife back in and hadnt broken a ring gear yet.
The only thing we could figure out was that the prodrive would flex when you put 700whp to it. I may be wrong, but that is my opinion on it.
art
Old Oct 17, 2002 | 03:58 AM
hondaswaper's Avatar
Default Re: Quaife or ProDrive Spool (Arturbo)
QUAIFE all the way........the spool has twice the shock load on your axles/tranny as the quaife........
Old Oct 17, 2002 | 06:58 AM
b18bturbo's Avatar
Quiafe all the way.
Old Oct 17, 2002 | 08:07 AM
earl's Avatar
Default Re: Quaife or ProDrive Spool (b18bturbo)
Buy your discounted Quaifes from me. OK, I know that was a shameless plug but with all the endorsements, I couldn't resist.
Old Oct 17, 2002 | 09:06 AM
KCHybrid's Avatar
Default Re: Quaife or ProDrive Spool (earl)
I plan to when I am unbroke like I curently am.
Old Oct 17, 2002 | 09:36 AM
Default Re: Quaife or ProDrive Spool (KCHybrid)
I already talked to chris. I know about it and the prices. Just wanted to know spool over quaife. Where have you been at HIDING?
Old Oct 17, 2002 | 10:32 AM
madman604's Avatar
the welded Diff is illegal because welding the gears weakens them, making them prone to snapping as opposed to the spool which is a solid billet piece. as you mentioned, snapped axel/diff = ride into the wall
Old Oct 17, 2002 | 08:13 PM
TurboDANDEE's Avatar
Earl, how much for the Quaife for Ls/B16 and do u have them in stock?
Old Oct 17, 2002 | 08:35 PM
SEFIxCivic's Avatar
what kinda of axles are you superfast guys that run quaife using? dont most big hp axles require you to run a custom spool?
Old Oct 17, 2002 | 09:57 PM
ninesecrx's Avatar
Default Re: Quaife or ProDrive Spool (SEFI8LOxCivic)
If you run Nitro or Mark Williams stuff, they use their own spools. The extreme suspension axles you retain what ever you want...Jojo uses a Quaife and I think Jotech uses their stuff as well with a Quaife. I use a Quaife and DSS 5's on my car.
