Quaife Install help!
Old Aug 25, 2002 | 02:32 PM
Scott - 93HB Si's Avatar
Default Quaife Install help!
I'm installing my quaife right now, and it doesn't have the speedo driver gear.
I did a search and found that I have to use a gear puller to pop the speedo gear off the factor diff. I only have a 2 arm gear puller, will this be sufficient? or is the speedo gear really fragile and I should wait till I can get a 3 arm one???
Old Aug 25, 2002 | 02:41 PM
earl's Avatar
Default Re: Quaife Install help! (Scott - 93HB Si)
Use some PB Blaster on the gear and gently use your 2 arm puller and you should be fine.
Old Aug 25, 2002 | 05:09 PM
Holden's Avatar
Heat it up with a propane torch for removal and reinstallation.
paopao
Transmission & Drivetrain
Jun 14, 2010 10:40 AM
AdamQ3B85
Honda S2000
10
May 2, 2005 02:52 PM
blkb18
Mar 17, 2005 06:33 PM
