PWR rad users- what fan?
Old Jun 6, 2004 | 07:15 PM
pissedoffsol's Avatar
25 Year Member
Default PWR rad users- what fan?
what fan are you guys using?
i had a fal slimline, and it melted to my downpipe.
what else is an option?
Old Jun 7, 2004 | 11:26 AM
25 Year Member
Default Re: PWR rad users- what fan? (pissedoffsol)
ANYONE?
Old Jun 7, 2004 | 11:29 AM
94gsr4dr's Avatar
I run a pusher fan on mine. The downpipe is just to close even with a slimline.
Old Jun 7, 2004 | 11:41 AM
PM-Performance's Avatar
Default Re: PWR rad users- what fan? (94gsr4dr)
i just use an Auto Zone Imperial Fan set up pusher on mine . works great
Old Jun 7, 2004 | 11:51 AM
Armaan's Avatar
Default Re: PWR rad users- what fan? (itr206)
The Full-Race staff should know...I think they recommend the PWR 92+ CIV's for their customers (using the FR manifold).
Old Jun 7, 2004 | 12:19 PM
macrosshn's Avatar
the son and the heir
Default Re: PWR rad users- what fan? (Armaan)
This may be a bit off-topic, if so, I apologize. But how do you mount a pusher fan. I've read the threads about them and there seems to be plastic mounts pushed through the radiator to hold them in place. How is this so? Won't it cause a leak?
Old Jun 7, 2004 | 03:48 PM
AVATAR's Avatar
Default Re: PWR rad users- what fan? (macrosshn)
I bought a pusher fan through Jegs and mounted that to my PWR. The little zip ties go through the fins fine and should never cause a leak. I did a write up, dont know if it'll help . . .
https://honda-tech.com/zerothread?id=750219
Old Jun 7, 2004 | 03:57 PM
sneakypete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">what fan are you guys using?
what else is an option?</TD></TR></TABLE>
I'm running an Autozone special Imperial Pusher fan on mine.
Old Jun 7, 2004 | 04:01 PM
Forrest Gump 9's Avatar
Default Re: PWR rad users- what fan? (sneakypete)
[QUOTE=sneakypete]
That's exactly what I use, but I used a 14" on mine .
Old Jun 7, 2004 | 06:49 PM
Full-Race Javier's Avatar
i run a autozone pusher fan on my PWR 1/2 rad too... are you running a dump tube on the wg?
Old Jun 7, 2004 | 07:00 PM
SiRkid's Avatar
Default Re: PWR rad users- what fan? (Full-Race Javier)
what about fan shrouds???? is that not part of making a fan work well?
Old Jun 7, 2004 | 07:16 PM
c jackson's Avatar
threes
Default Re: PWR rad users- what fan? (SiRkid)
yay for the cheap *** autozone fan!
Old Jun 7, 2004 | 07:20 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Javier &raquo;</TD></TR><TR><TD CLASS="quote">i run a autozone pusher fan on my PWR 1/2 rad too... are you running a dump tube on the wg? </TD></TR></TABLE>
no dump... haven't boosted it enough (like 4 psi is as high as shes seen when she was working) to even open the WG yet... and now i got all these fuel pump problems and melted fans
and yes, its a 1/2 92-95 rad... which fits like **** in the sol i might add. feet don't line up. i need to cut some of my headlight metal area assembly to fit it to spec... but thats the last of my worries right now
of course, it broke off my rad... damn bolts sheared right off. so my rad is toast too, at least as far as mounting another fan goes on the back side...
nice meltage:
how did you guys mount the fan to the front side?
Old Jun 7, 2004 | 07:25 PM
i just ran the fan in the front and mounted it with those zip tie things that come with it.
Old Jun 7, 2004 | 07:27 PM
25 Year Member
right... but to what?
Old Jun 7, 2004 | 07:31 PM
the zip ties fasten the fan to the rad....they go through the fins of the rad.
Old Jun 9, 2004 | 09:52 AM
25 Year Member
picked up a 12" pull/push reversible fan for $68 out the door.
i'll let ya'll know how it goes.
Old Jun 9, 2004 | 10:03 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">what about fan shrouds???? is that not part of making a fan work well?</TD></TR></TABLE>You must be a V-8 guy?
Fan shroud is for when the fan blades are far away from the radiator. When the fan is mounted to the radiator, there is nothing to shroud.
BTW, a stock civic fan will bolt right to the back of a PWR. I guess you could say that has a little shroud around it. I've never seen a shroud with an aftermarket fan, however.
platinum00
Jul 30, 2006 07:55 AM
rice is nice
Apr 3, 2006 05:27 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
InLimbo87
Jul 21, 2004 07:22 AM
