purpose of returnless fuel system?
Old Jan 5, 2004 | 12:26 PM
dfoxengr's Avatar
Default purpose of returnless fuel system?
what is the point and technically how is it done?
do you need a FPR put somewhere else with this method?
Old Jan 5, 2004 | 05:33 PM
dfoxengr's Avatar
Default Re: purpose of returnless fuel system? (hybridvteceg)
bump?
Old Jan 5, 2004 | 05:45 PM
RenoRacing's Avatar
I haven't heard much of any benefits from them, I know that the newer civics/rsx's have them but when swapped into other chassis(EG/EK) I believe they change that to a return setup. I did notice this setup the other day on HoustonSi's car, don't know any details, here's the link to a picture of it though.
looks odd!
https://honda-tech.com/zerothread?id=722708
Old Jan 5, 2004 | 05:49 PM
dfoxengr's Avatar
Default Re: purpose of returnless fuel system? (RenoRacing)
thats a link to log manifold post...?
Old Jan 5, 2004 | 06:14 PM
Del_Slowest's Avatar
thats the pic he wants you to look at .....
Old Jan 5, 2004 | 07:29 PM
dfoxengr's Avatar
Default Re: purpose of returnless fuel system? (Del_Slowest)
oh so basically the FPR is moved upstream of the rail, and the other end of the rail is plugged.
do you have to use an inline pump?
Old Jan 5, 2004 | 07:31 PM
baphomet's Avatar
Are you sure that is return less?
Old Jan 5, 2004 | 07:42 PM
hpfsi's Avatar
There is still a return line, but if that setup works fine then why not just put the filter and regulator back by the tank right after the pump and all but do away with the return line? Sexy engine bay though
Old Jan 5, 2004 | 07:45 PM
XSIintegra's Avatar
Default Re: purpose of returnless fuel system? (hpfsi)
By the looks of it, the return line may be right below the regulator that is attached to the firewall. As hpfsi mentioned, the system would be cleaner and just as effective if the line is regulated before it hits the rail.
Old Jan 5, 2004 | 07:55 PM
baphomet's Avatar
Default Re: purpose of returnless fuel system? (XSIintegra)
I see, but I thought we were speaking of return-less fuel systems. Admittingly I know nothing about the subject, but even if you put the fpr at the tank it would still 'return' the excess fuel. Is that all it is?
I thought on the newer cars the pump works less/more depending on pressure needs.
Old Jan 5, 2004 | 08:09 PM
RenoRacing's Avatar
Default Re: purpose of returnless fuel system? (slashDEVslashNULL)
I'm not sure, that system just looks unusual to me, it does have a return line on the bottom of the regulator but the feed is a straight through design which is unusual. I believe returnless systems have a rpm dependent voltage supplied to the pump and raises pressure/amount as needed.
Old Jan 5, 2004 | 08:13 PM
XSIintegra's Avatar
Well, I know this doesn't count, but my Suzuki Samurai has a returnless fuel system (I do believe). It has a mechanical fuel pump w/ a single inlet and outlet. Inlet is from the tank and outlet is to the carb, although the carb is internally regulated.
Old Jan 5, 2004 | 08:36 PM
leadfoot78's Avatar
I used to own a 2001 civic and I know that had a returnless fuel system. The only thing I remember about it is that it made putting a turbo on the car alot more difficult. Some people converted to a system with a return line and some waited for the turbo kits from Greedy and others. The companies making the kits took a long time to come out with the turbo kit's cuz of the fuel system.
Old Jan 5, 2004 | 09:38 PM
dfoxengr's Avatar
Default Re: purpose of returnless fuel system? (leadfoot78)
weird, but are there advantages disadvantages of returnless? and is it technically just plugging up the return line?
Old Jan 5, 2004 | 10:12 PM
leadfoot78's Avatar
Only fuel economy and emissions would benefit from some thing like that. It's just a pain in the ***, that 2001 Civic was a pain in the *** to work on, from turbo to putting in speakers and stereo it was a pain in the ***. Thats why I drive an EG now and I would never go back.
dfoxengr's Avatar
ok thanks.
Old Jan 6, 2004 | 04:05 PM
dfoxengr's Avatar
autotec
May 31, 2016 08:09 AM
attack666
Jul 11, 2010 04:46 PM
HickamHatch
Feb 3, 2009 10:50 AM
Boosted_B_Series
Nov 10, 2008 03:29 PM
slwazgsr
Oct 28, 2002 08:29 AM
