Pros and cons to using a ls water pump on a B18c
Old Apr 8, 2006 | 04:35 PM
AllmotorEH2's Avatar
Default Pros and cons to using a ls water pump on a B18c
Ok so heres the deal. I just recieved my greddy timing belt and it turns out it is for a ls motor. I know i can still use it however i would have to run a ls water pump. My question is i am looking at putting down 5-600whp will the ls water pump be efficient enough to run this belt. Or should i buy a new one?
Thanks Joel
Old Apr 8, 2006 | 06:20 PM
dornon13's Avatar
Default Re: Pros and cons to using a ls water pump on a B18c (AllmotorEH2)
dont do it....get the right pump....it will spin slower i wouldnt want to do it if i were planning on putting near that much power
Old Apr 8, 2006 | 06:33 PM
non-VTEC's Avatar
Default Re: Pros and cons to using a ls water pump on a B18c (dornon13)
actually using the LS pump would spin faster........which is a ok idea for low rpm use......but once the rpm reaches a certain point (7500rpm+) the pump spins to fast and the pump becomes inefficient.
Old Apr 8, 2006 | 07:46 PM
dornon13's Avatar
Default Re: Pros and cons to using a ls water pump on a B18c (non-VTEC)
my B i couldnt remember if it had more or less teeth
Old Apr 8, 2006 | 08:15 PM
cool thanks for the responses im just gonna get the "right" timing belt haha appreciate your input
Old Apr 8, 2006 | 10:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (AllmotorEH2)
i thought all the pumps where the same from 96+
soon2bdropped
Jul 22, 2007 11:33 AM
shortyz21
Nov 12, 2006 08:38 AM
19sec beast
Mar 31, 2006 04:40 AM
alfee
Nov 28, 2005 09:37 AM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
