Pros and cons of having a O2 sensor by the Turbo
Old Nov 6, 2007 | 03:06 AM
Quickgti1.8t's Avatar
Default Pros and cons of having a O2 sensor by the Turbo
To make the install a little easier i was thining of buying these V-band adaptors. My turbo has a 3" V-band housing
Now would the sensor get the correct readings, if it going to be too hot for the Bosch O2 sensor
http://www.atpturbo.com/Mercha...-FLS3
Old Nov 6, 2007 | 04:13 AM
Flashmn's Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (Quickgti1.8t)
Probably not going to be too hot. As long as its not between manifold and turbo you should be fine and the sensor needs to be hot to get a reading.
Mine is about 5-10cm away from the turbine side.
Old Nov 6, 2007 | 05:37 AM
twkdCD595's Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (Flashmn)
here is a quote from the ngk wideband install instructions... I found it to pertain to this topic.
"Below are recommended guidelines for installing the AFR sensor. Some exhaust configurations may make it difficult to meet each of the recommendations exactly, and some compromise in mounting may be required. The sensor does not necessarily have to precisely meet every mounting guideline below to operate, but please understand that the better you conform to these rules, the longer the sensor will last and the more accurate the results will be.
The AFR sensor should be located between 12” and 48” from the engine, upstream of any catalyst device if so equipped. The closer the sensor is to the engine, the more likely it will be overheated, possibly shortening its life. The further it is from the engine, the more likely condensed water will get into the sensor and thermally shock it, again possibly shortening its life. The sensor should be mounted at least ten exhaust diameters upstream of the exhaust exit (ex. for a 3” exhaust pipe, that is 30”). If the sensor is mounted between one and ten exhaust diameters from the exhaust exit, the AFR measured will be leaner than the actual AFR by as much as 2 AFR at low engine speeds (i.e. less than 3000 rpm).
Make sure there are no leaks in the exhaust system, as this will create an artificially lean (higher) AFR reading. Also, install the sensor upstream of any factory air-injection if so equipped, as this too will cause a false lean reading.
In turbocharged applications, it is recommended that the sensor be installed downstream of the turbine. This is due to the fact that the high pressures before the turbine can distort the AFR reading. Apply the same installation guidelines as described above, but take into consideration that the sensor needs to be downstream of the turbine."
Old Nov 6, 2007 | 06:08 AM
tony1's Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (twkdCD595)
The bosch sensors are fragile to begin with, i wouldn't dare mount one that close to the turbine for any length of time.
Old Nov 6, 2007 | 06:54 AM
.CUBISH.'s Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (tony1)
you could always just use that at the end of your downpipe
Old Nov 6, 2007 | 07:28 AM
TiAL's Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (.CUBISH.)
mine is right before the flexpipe
Old Nov 6, 2007 | 08:28 AM
blaze the chemi's Avatar
Default Re: Pros and cons of having a O2 sensor by the Turbo (TiAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">mine is right before the flexpipe</TD></TR></TABLE>
That's where i'd put mine on my next setup and have an e-cutout after the flexpipe before the cat.
My tuner put the bung for the wideband 18" after the turbo because he said for longevity it would be good, yet still get an accurate reading.
Old Nov 6, 2007 | 02:20 PM
ham's Avatar
ham
I think that flange will burn up the sensor. Its pretty much a flame right there next to the turbine.
Old Nov 6, 2007 | 03:43 PM
Topdawgg's Avatar
i dont know if being to close caused it, but my wideband sensor was close to the flange at the top of my vband downpipe... it was a topmount, so the runners of the manifold were long enough to be within specs... I still burnt out my sensor after a month of being street tuned and a few passes on the dyno....
Ill probably put it down by the flex pipe over winter.
1320vickers
Feb 17, 2019 09:09 AM
incubusboy87
Jun 7, 2007 03:25 PM
TurboJesse
Sep 19, 2003 03:26 PM
Blown90hatcH
Jan 7, 2003 02:37 PM
EU BATT
Nov 21, 2002 02:48 PM
