Progressive nitrous controller and Hondata
I have just got a progressive nitrous controller, and i would like to know know how i can get this wired into my setup along with my hondata to drive my direct port dry kit.
Why would i do this? well i want to used hondata to control my fuel and retard the necessary timing. And i would like the progressive controller to be installed to deliver the nitrous how i want it to come on through out they rpm range.
how do i go about doing such ?
I have not used a progressive controller before only the s300 nitrous software. But I have a friend who has one on his vw. It sounds like you should be able to wire it so the hondata can turn the controller on and off. As long it's set to rpm base and not time base for the progressive controller you should be ok.
The s300 nitrous software has 3 stages of nitrous control that you can set by rpm,tps, and mph. If you use the progressive controller even in time base as long as you set it up as multiple stages and turn each stage on and off at different mph it will work.
What progressive controller do you have? The hondata will need to know when the system is on and off. So you should be able to just use the nitrous input and not the output. Sorry I don't have a progressive controller to try it out.
cornhusker
Dec 17, 2003 08:48 PM
