Profec E-01's worthyness
Old Nov 2, 2005 | 08:19 AM
chihuahuamanx's Avatar
Default Profec E-01's worthyness
I've heard pretty bad things about the profec II, so i dont think ill be going with it. THe profec E-01 (the one with the full display and all) looks appealing, but there isnt much info on here as to how it actually performs? Any opinions? Any other suggestions? thanks.
Old Nov 2, 2005 | 09:00 AM
Default Re: Profec E-01's worthyness (chihuahuamanx)
bump
Old Nov 2, 2005 | 09:01 AM
seen4ever's Avatar
apexi avc-r is proven to be a good system, why not go for it?
Old Nov 2, 2005 | 09:42 AM
Default Re: Profec E-01's worthyness (seen4ever)
i havent looked much into it, i will. Ive just heard so many bad things about the SFAC so i was kinda staying away from it. Ill check it out and see what I think. Any thoughts on the profec though?
Old Nov 2, 2005 | 10:01 AM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx &raquo;</TD></TR><TR><TD CLASS="quote">i havent looked much into it, i will. Ive just heard so many bad things about the SFAC so i was kinda staying away from it. Ill check it out and see what I think. Any thoughts on the profec though?</TD></TR></TABLE>
are you talking about the SAFC? if you are, the AVC-R and SAFC are 2 totally different things. AVC-R is a boost controller and the SAFC is a ecu piggback.
Old Nov 2, 2005 | 10:03 AM
Default Re: Profec E-01's worthyness (Honda Sport)
I know, i know, but they're both electronic controllers made by the same companies and the bad things id heard about the SAFC didnt help the AVC-r.
Anyone use the HKS boost controllers?
Old Nov 2, 2005 | 10:48 AM
seen4ever's Avatar
SAFC works exactly how it is labeled to do.
i've never head anyone have any issues with AVC-R. it takes a bit to get used to, but the gear dependent boost is fun.
the HKS controller is good too.
Old Nov 2, 2005 | 02:13 PM
there are two HKS controllers ive seen, which one would you be referring to?
Old Nov 2, 2005 | 02:30 PM
19t EX coupe's Avatar
&lt;---- would also like to know, because I'm about to invest in a Profec E-01
Old Nov 3, 2005 | 01:25 PM
Default Re: Profec E-01's worthyness (19t EX coupe)
lets bump it up, theres not too much info out there on the E-01
steveDC2
Oct 30, 2010 03:29 AM
beaversdc5
12
May 27, 2007 10:37 AM
Apex i ITR
Honda Motorcycles
15
May 27, 2005 01:09 PM
ozzfreak
Jan 5, 2005 07:29 PM
rjr162
May 24, 2004 06:47 AM
