prodrive pump gears question??
Old Sep 24, 2002 | 09:31 PM
1fstevo's Avatar
New User
Default prodrive pump gears question??
Have question on the pump gears if anyone have any comments.
The prodrive pump gear look identical to the oem gears except the inner gear has an engrave " prodrive " lettering. The outer gear look totally stock. How would you examine if the outer gear is prodrive?
Second question.
I have noticed on my prodrive pump gears that the inner gear can only fit with prodrive outer gear, it will not fit in with oem pump gear but oem inner gear can go in both oem and prodrive outer gear. Is this normal?
[Modified by [Evo]Hybrid, 6:34 AM 9/25/2002]
Old Sep 24, 2002 | 09:40 PM
tony1's Avatar
Default Re: prodrive pump gears question?? ([Evo]Hybrid)
I would recommend sticking with the stock gsr oil pump. I have heard of quite a few pro drive gears breaking and I've never had a problem with a stock gear.
Old Sep 24, 2002 | 09:42 PM
1fstevo's Avatar
New User
Default Re: prodrive pump gears question?? (tony1)
Really? I have only heard good things about them, I actually did a search from previous post see what people say and have not found any negative feedback unless I missed some of it.
The gear is identical in size, weight, and design. The grain on the gears are like the same too.
Old Sep 24, 2002 | 10:05 PM
Arturbo's Avatar
Better than steak
25 Year Member
I agree with this.
Old Sep 24, 2002 | 10:23 PM
Flamenco-T's Avatar
Default Re: prodrive pump gears question?? (Arturbo)
yep and I have seen an actual prodrive gears shatter, it took me a few looks to realize it's actually an oil pump gear...
stan
Old Sep 24, 2002 | 10:55 PM
1fstevo's Avatar
New User
Default Re: prodrive pump gears question?? (Flamenco-NA)
wow, did you guys measure the clearance on these things?
Old Sep 24, 2002 | 11:01 PM
Arturbo's Avatar
Better than steak
25 Year Member
A list of people who used Prodrive oil pump gears then went back to stock:
Lisa Kubo
Sav Leone
Viren
Kenny Tran
Venom
FYI, tony1 is the crew chief for Kenny. Good work tony
art
Old Sep 24, 2002 | 11:07 PM
1fstevo's Avatar
New User
That is so funny!!! I just read the DRAG magzine and prodrive advertised their product backed by lisa kubo. hehe.
Should I let it shatter then take it out or take it out now and toss it in the bin. hum...
Old Sep 25, 2002 | 05:17 AM
KCHybrid's Avatar
Lisa Kubo
Sav Leone
Viren
Kenny Tran
Venom
art
This just made my mind up, I was pretty convinced that I was not going to get one but that seals it.
Old Sep 25, 2002 | 06:06 AM
Dublocivic's Avatar
Default Re: prodrive pump gears question?? (KCHybrid)
Another wasted 200+ dollars on a **** product.
kidkutz's Avatar
that's funny...didn't viren have a groupbuy on these? wait! i think i bought one too!
Old Sep 25, 2002 | 07:28 AM
b18bturbo's Avatar
Default Re: prodrive pump gears question?? (Dublocivic)
just dont run them with methanol setups they are okay product for stock oil pump setup just make sure you check the clearances with a feeler gauge like vaportrail did. ITs always good thing they sent him the wrong one.
Viren
I also stick with stock just because it works and plus i usually replace the motor after so mnay passes anyways.
Old Sep 25, 2002 | 08:49 AM
Dublocivic's Avatar
Default Re: prodrive pump gears question?? (b18bturbo)
Im going to be on 116-118 so with my car being a street/track I suppose the PD oil gear should still be used then? I have a 55 gal drum of 116 sitting at the shop waiting to be burned Let me know if you think its alright to run it or if I should just run a stock GSR pump. Thanks!
Old Sep 25, 2002 | 10:02 AM
hondaswaper's Avatar
why do they fail with methanol?? we haven't broke ours......(knock on wood)
Old Sep 25, 2002 | 10:14 AM
b18bturbo's Avatar
Default Re: prodrive pump gears question?? (hondaswaper)
bleive me it will fail with methanol it wil fail quick.. alot of broken gears due to that. setup with methanol
Old Sep 25, 2002 | 10:30 AM
FB in SA's Avatar
What about h-series prodrive gears? I bought mine because I heard that h-series gears fail. A lot.
I looked at it as cheap insurance for the rest of this expensive *** motor.
Mit
Old Sep 25, 2002 | 10:45 AM
Bnjmn's Avatar
I read here that the stock gears let go after 350hp or so? Any problems with the Toda oil pump gear?
Ben
Old Sep 25, 2002 | 10:54 AM
b18bturbo's Avatar
Default Re: prodrive pump gears question?? (Bnjmn)
just get a new oil pump and be fine with it. The best setup ofcourse is dry sump but thats cost money.
Old Sep 25, 2002 | 01:10 PM
Dublocivic's Avatar
For longevity’s sake should I stick with a stock gsr pump or utilize the prodrive gear?
I dont have the money or time to tear down after every or every other event..
Because for as long as I can remember everyone was saying that if you start achieving over 400-500 whp you would shatter oil pump gears. Was this due to harmonics? detonation? has the switch of beliefs to going back to stock because of better engine management?
Im not angry or anything.. I just want to know what to run.. I dont want the **** to shatter on me
Thanks,
Adam
[Modified by Dublocivic, 5:10 PM 9/25/2002]
[Modified by Dublocivic, 5:14 PM 9/25/2002]
[Modified by Dublocivic, 5:53 PM 9/26/2002]
Old Sep 25, 2002 | 09:03 PM
1fstevo's Avatar
New User
Mine are already in so I'm just going to see when it will shatter. I hope it'll hold till next year.
Old Sep 25, 2002 | 09:07 PM
Gmedalion's Avatar
It should hold up fine if your running gas.
Old Sep 25, 2002 | 09:14 PM
1fstevo's Avatar
New User
Default Re: prodrive pump gears question?? (Gmedalion)
Nm
[Modified by [Evo]Hybrid, 6:14 AM 9/26/2002]
Old Sep 25, 2002 | 09:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Why would running Meth or gas have anything to do with it?
All the racers using meth still use stock.
art
Old Sep 25, 2002 | 11:05 PM
BoostCreeper's Avatar
Just get your oil pump gear done at Street Strip and all will be well Yeahh Rigghht!!!!
Old Sep 25, 2002 | 11:54 PM
VaporTrail's Avatar
New User
as long as you measure your clearances with the prodrive, as they recommend, you should have no problems with their gears. All you need is a simple set of feeler gauges, and a Helms manual, both of which you should have if you are assembling your motor anyway.
