Problems with my IAC valve
Old Feb 28, 2006 | 04:53 PM
elguluso's Avatar
Default Problems with my IAC valve
Does anyone know if an IAC valve code would cause my turbo car to break up while boosting, I have tried everything to get rid of the AIC valve code the only thing I have not tried is to repin the wires to the ecu, Im running a JDM GSR block with a JDM CTR head and I have 9.5:1 compression (the compression tester reads 180 across after warming up the engine) if anyone ever had this problem and knows how to fix it let me know.
Thanks
Old Feb 28, 2006 | 06:56 PM
BoostGoneWild's Avatar
Default Re: Problems with my IAC valve (elguluso)
You might wanna try to regap your pugls and also check the heat renge.
MMB76
22
Nov 18, 2014 06:00 AM
"93XSi"
Dec 24, 2005 09:22 PM
blowme
May 2, 2005 04:38 AM
niceguy12
Jan 8, 2005 02:52 PM
munscher
Nov 24, 2002 04:48 PM
