problems with E-cutout
Old Dec 14, 2003 | 07:03 PM
LiLOtaku's Avatar
Default problems with E-cutout
Has anyone blown any fuses with the E-cutout?
I just installed my e-cutout and I keep blowing the fuse that it came with. I've tested the e-cutout previously and it was working fine, and now it just keeps blowing the fuse whenever I try to open and close the unit?
Its the one made by Quicktime Performance. I have the power line hooked up to my 12v radio power, and I grounded everything properly.....
anyone help?
Old Dec 14, 2003 | 07:41 PM
pornstarSR's Avatar
Default Re: problems with E-cutout (LiLOtaku)
truthfully if its blowing fuses its probably something with your wireing..
but it could be the cutout too..
try connecting the power side to a different power source other than the radio one....and also try grounding it somewhere else...
wireing problems suck
Old Dec 14, 2003 | 07:54 PM
egturbo's Avatar
mine are fine... i've had the e cutout on my car for bout two weeks. and i open and close it alot haha.. its nice i see a cop just flip the switch its quiet
Old Dec 14, 2003 | 08:32 PM
Del_Slowest's Avatar
Default Re: problems with E-cutout (egturbo)
Sand the area where you ground at. Sometimes it doesn't like to work through paint. Also, what watt fuse is it. I keep blowing heater fuses in my cavy so i got a windshield wiper fuse. When it blows, just let it cool down for 2 sec then it'll flip right back on. Save you a lot on fuses
Old Dec 14, 2003 | 09:25 PM
LiLOtaku's Avatar
Default Re: problems with E-cutout (Del_Slowest)
I already did a test on the switch itself, and doubled checked my wiring already. The switch itself was pushing out 12 volts wich is fine.
I just don't get why the valve itself is pushing more than 10 amps of current. weather closing it or opening it.
Old Dec 14, 2003 | 10:55 PM
Full-Race Javier's Avatar
hmmm....is the valve binding at all? whats the fuse rated for? we have some at the shop, ill double check what they are rated for tomorrow.
Old Dec 15, 2003 | 12:51 AM
1bar's Avatar
Default Re: problems with E-cutout (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">
wireing problems suck</TD></TR></TABLE>
i agree
goodluck
Old Dec 15, 2003 | 01:23 AM
Full-Race Henry's Avatar
for the ground, just find a good ground. and for power, just find a good power.
JK
We hooked mine up to the ignition power off of the ecu. works perfect.
Old Dec 15, 2003 | 07:21 AM
falcongsr's Avatar
What is this crap?
sounds like you have a short somewhere cause i dont think that little motor could draw 10 amps. also check the voltage at the motor when the motor is opening/closing the cutout, see if it drops below 10v. which would indicate a problem with where you're getting your power.
green eyed bandit
Nov 16, 2011 06:14 AM
Outlaw-Hondaz
Oct 6, 2010 09:02 PM
JBN241
Audio / Security / Video
Apr 6, 2009 12:27 AM
idumpwitmy12gaugepump
May 22, 2008 07:18 PM
DualCamDan
11
Aug 13, 2005 03:22 PM
