Problems With Drag III Kit and Integra JDM Front End
Old Feb 22, 2004 | 04:41 PM
mazdaspeed00's Avatar
Default Problems With Drag III Kit and Integra JDM Front End
Does anybody use the drag III kits for there integra with jdm front end have problems with the tial wastegate interfereing with closing the hood? Sorry for such an OT topic, but i want to know any problems people have faced with jdm front and drag III kits. Any problems and solutions that you have, what what you did to fix it would be appreciated.
Thanks in advance
Old Feb 22, 2004 | 04:53 PM
Mase's Avatar
Default Re: Problems With Drag III Kit and Integra JDM Front End (mazdaspeed00)
i didnt have a drag 3 mani when i had my jdm front on my old teg, but i had the inline pro, without the elbow installed, it would clear just fine, however i added a elbow for the dump anyways.
if you have a problem, just get a 90 degree elbow.
Old Feb 22, 2004 | 04:57 PM
Default Re: Problems With Drag III Kit and Integra JDM Front End (Mase)
thanks alot mase. i just want to make sure about everything before i get the kit.
Old Feb 22, 2004 | 05:05 PM
Mr.DC2TurBo's Avatar
it will rub a little on the hood but u should be able to close it.
Old Feb 22, 2004 | 07:38 PM
Pootie's Avatar
i dunno bout tegs but when u use a drag kit and tial wastegate on civics, it doesn't rub until u add a fitting to the top port and puts a nice lump in ur hood every time the engine torques back
Old Feb 22, 2004 | 07:45 PM
PureTeg420's Avatar
Default Re: (Pootie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie &raquo;</TD></TR><TR><TD CLASS="quote">i dunno bout tegs but when u use a drag kit and tial wastegate on civics, it doesn't rub until u add a fitting to the top port and puts a nice lump in ur hood every time the engine torques back</TD></TR></TABLE>
I ground maybe an inch I think (been over 3 years) off of that top fitting and it clears just fine now.
Old Feb 23, 2004 | 02:48 PM
turbopimp's Avatar
Default Re: (PureTeg420)
Some people just replace the aluminum banjo fitting with a much shorter steel or brass fitting... then again the 90 deg elbow is a good solution as well. Import Parts usually has them in stock.
Old Feb 23, 2004 | 04:36 PM
BoostedSi's Avatar
Default Re: (turbopimp)
i got a drag elbow if ya need it. 20bux shipped PM if ya need it. For some reason the h-t email notification doesnt work anymore on my computer
Old Feb 23, 2004 | 04:48 PM
Muckman's Avatar
Moderator in Chief
Default Re: (BoostedSi)
I hacked my hood frame to allow clearance for the upper tial fitting on my G3 GSR.
Dunc
May 12, 2005 05:03 PM
BobGnarly
Oct 20, 2004 05:17 PM
SoSoJeff
Aug 6, 2002 04:49 AM
a z n t a k
Apr 15, 2002 09:22 PM
