Problems with CM Stage 4
Old Oct 10, 2002 | 10:29 PM
Red99CivicSi's Avatar
Default Problems with CM Stage 4
I bought the CM stage 4 and used a centerforce 13 lb flywheel on my gsr tranny. I am using good fluids and i think i have bled the clutch enough. The stock feel of the clutch was a concern but other people told me theirs felt stock also. My other concern is that the clutch doesnt engage until late. Other people using this clutch told me that it engaged early. What are some opinions on why it is engaging so late and why it feels just like stock?
Old Oct 11, 2002 | 01:11 PM
Default Re: Problems with CM Stage 4 (Red99CivicSi)
Anybody have any opinions or clues to why this is. Its gotta be installed right considering I have raced it on 6 lbs and it holds perfect. Thanks
Old Oct 11, 2002 | 01:54 PM
turbopanda's Avatar
My CM stage 4 clutch feels like stock, but biting point is very short.. pushing my foot on the clutch by less than 1cm is the difference from the clutch not grabbing to fully grabbing. It can be a bitch, because if you're not used to it, you'll be stalling your engine all the time People are always looking at me coz I have to rev the engine a little in order to take off smoothly..
Old Oct 11, 2002 | 02:38 PM
Rocket's Avatar
Default Re: Problems with CM Stage 4 (turbopanda)
The reason it catches high is because the disc doesn't have the marcel "flat spring" This will cause the engagement to be a little higher than with a stock disc. You should be cool though.
Old Oct 11, 2002 | 04:57 PM
SuperTeg95's Avatar
Default Re: Problems with CM Stage 4 (Rocket)
there is an adjustment under the dash which allows you to change when it releases(on the floor or at the top), but not able to adjust quickness. I have mine disengage at the top of the peddle(sp?), that way I just gotta tap it instead of pushing it all the way to the floor.
Old Oct 11, 2002 | 05:47 PM
B20LS-T's Avatar
New User
Default Re: Problems with CM Stage 4 (SuperTeg95)
Did you break in the clutch 500 miles? If so, the clutch will grab good and might chatter a bit. Mine feels like stock and im using a stage 3 PP and type R flywheel.
95_red_dc
Transmission & Drivetrain
13
Nov 10, 2008 03:16 PM
b20gsr10.9
Dec 14, 2007 02:24 PM
CivilizedCiv
Jan 25, 2002 07:17 AM
GReddySetGO
Nov 21, 2001 04:26 PM
