Prelude Injectors in Integra for boost?
Old May 25, 2006 | 01:32 AM
95dc2teg's Avatar
Default Prelude Injectors in Integra for boost?
Will the 92-96 Prelude Injectors w/ a resistor box (320cc) be good enough to put in a 1995 Integra GS-R running 7psi of boost? Also are the prelude injectors 320cc or 345cc? Either way will it work?
Old May 25, 2006 | 05:04 AM
ham's Avatar
ham
Default Re: Prelude Injectors in Integra for boost? (95dc2teg)
7psi with a good setup could give you close to 300 crank hp which would be pretty much maxing out the duty cycle of those injectors. to be safe you should get some RC550s or at least some dsm 450s.
i have 13psi on a stock gsr and dsm 450s werent cutting it, had to get the 550s.
Old May 25, 2006 | 07:37 AM
Turbocivic94's Avatar
345cc and they should work fine
Old May 25, 2006 | 07:43 AM
yee SERIOUS's Avatar
i think so. it's better than 310's. my cousin ran 310's with an fmu on his ls motor. ran fine. if you're going to run chipped ecu, i would recommend to just get dsm450's at the least though.
boostedteg15
Mar 4, 2006 08:37 AM
h22slohatch
Aug 27, 2005 11:18 AM
Austin
Oct 16, 2002 10:08 AM
T.Werd
Dec 7, 2001 08:28 AM
