Precision Turbo selection??? 6262 or 6765
Old Apr 30, 2011 | 05:24 AM
Gofastturnleft's Avatar
Default Precision Turbo selection??? 6262 or 6765
My boosted GSR project has been stalled for most of the winter but now i am back home and can start ordering parts. Now up untill me reading a few threads I was 100% sold on the Precision 6262 turbo. The numbers being put down are awesome for the price!!!!!! But I was wondering if what you guys thought would be be better for my GSR. I was wondering if i should go with a ball bearing 6262 or a journal bearing 6765. Now with the 6765 i think lag will be an issue????? But im also worried about going to big because my motor has eagle rods that are only rated to 600 HP. So what do you guys think? Im leaning more towards the 6262 but figured i would throw it out there.
Thanks guys
Old Apr 30, 2011 | 05:35 AM
kyden's Avatar
Default Re: Precision Turbo selection??? 6262 or 6765
what's your setup and what are you looking for power?
Old Apr 30, 2011 | 05:49 AM
92redhatch's Avatar
People have make 900whp on eagle rods. I made 522. I run a 6765 just because I want big power but the 6262 is a great turbo.
Old Apr 30, 2011 | 07:20 AM
As far as my set up goes. I have a b18c1 block ans heads with mahle pistons and eagle rods which say they are only rated to 600 hp ( i think there are two types of eagle rods?) full supertech valve train (springs, retainers, valves) stock polished and balanced crank moroso oil pan, skunk 2 intake manifold, power sport port matched throttle body and my fuel system is a walbro 255 with stock line and i will be ordering an AEM fuel rail and reg and planning on running fuel injection clinic max blue 1680's. As far as power i was hoping for 550ish??????????? I dont wannna go to hard and blow my block apart. I am also looking into get a water meth injection system. Still researching it tho. But the 6262 does look like a great turbo. but still wanna spend my money in the right places and dont want to regret not getting the bigger turbo right from the start! Also i will be running a speedfactory top mount. Will i have any clearance issues with these size turbos? I was planning and calling them before I ordered it to check and give them a heads up.
Old Apr 30, 2011 | 07:29 AM
92redhatch's Avatar
6262 can make 700+ without a issue
Old Apr 30, 2011 | 08:17 AM
Silva Bullit DC4's Avatar
X2.
I ran a journal bearing billet 6262 (.63 a/r) on my Benson sleeved GSR and loved it. It lagged a teeny bit more than I would have liked, but I had very short gearing, so I didn't mind it too much. Made 489 whp on a little 2.5" exhaust & RC 750cc's. The 6765 will be too big of an application for what you're trying to do. But 550 whp will be a walk in the park for that 6262.
Old Apr 30, 2011 | 09:00 AM
AllShowNoGo727's Avatar
If I had to pick between a DBB Billet wheeled 6262 or a 6765 journal bearing turbo, id pick the 6262 all day. If it was between a 6765 DBB Billet Wheel or 6262 in the same configuration, id pick the 6765.
Old Apr 30, 2011 | 11:53 AM
boostedBLUfg2's Avatar
even a 5857 might be a good choice for you, but i don't think youll quite make 550 with that. im guessing 500-525 at the max
Old Apr 30, 2011 | 01:35 PM
I think im gona go with the 6262 Any one know the best place for me to get one? aka cheapest place?
Old Apr 30, 2011 | 01:56 PM
NewKlear's Avatar
Thats the turbo i want to go with in 2 months
Old Apr 30, 2011 | 02:03 PM
racebum's Avatar
have seen them all over for less than $900 shipped. best net price i came across was 849 and i can't for the life of me remember where.
Old Apr 30, 2011 | 03:21 PM
Redline130's Avatar
Might not be the cheapest, but definitely the best (customer service wise), SpeedFactory. Very helpful and knowledgeable guys over there.
Old Apr 30, 2011 | 03:36 PM
H22ftw's Avatar
Glad i stumbled upon this thread.. i've got a very similar build going on with my gsr, and was considering the same turbo options. After talking to some local shops and researching some i've come to the decision of the billet 6262! Just ordered mine from Goautoworks for 895.
Old Apr 30, 2011 | 07:01 PM
Got mine from Shawn over at Ramey Built for 850 last year.
Old Apr 30, 2011 | 07:21 PM
The 6262 is probably the better choice, Only reason I would pick the 6765 is because my car is seeing a lot less street use than when I first started putting this car together and it would be nice to not have the little turbo If I wanted to run in a True Street Event or something.
Old Apr 30, 2011 | 10:20 PM
portenio78's Avatar
just put down 650 whp on a 6262, 25psi on e85 stock sleeve GSR. Went from the my little potent 30R, to this new turbo and only saw about 8-900 rpm lag difference. I'm so glad I did not go with the 67...i would have loss so much boost between shifts, since I only rev to 8800rpm.
Old May 1, 2011 | 09:19 AM
NewKlear's Avatar
Was that with the 6262 billet or billet ball bearing?
See I want to know the difference between the 6262 billet and the 6262 billet ball bearing I need to know if is worth spending the extra money for the ball bearing..
Old May 1, 2011 | 07:10 PM
portenio78's Avatar
6262 journal bearing.
Old May 2, 2011 | 02:35 AM
NewKlear's Avatar
I wonder who on here has use the 6262 ballbearing and if is worth it compare to the 6262 journal?
Old May 2, 2011 | 02:40 AM
TREESnoseeds787's Avatar
6262 journal bearing=best bang for your buck. I currently run one on my dsm and is a great all aorund turbo. Spools fast enough for the street and has enough ***** to flow 70lb/m.
Old May 2, 2011 | 02:44 AM
NewKlear, I made the numbers in my sig on a BB Billet wheel 6262. Ill never own a journal bearing turbo after using this 6262. Ive used only precision turbos, sc60 at first, than an sc61, both journal bearing turbos, and ive had my newest precision turbo(6262) for about 5 months now and love it, no going back to journals after this.
Old May 2, 2011 | 03:17 AM
NewKlear's Avatar
Thinking on spending that extra cash and buying the ballbearing...
Old May 2, 2011 | 03:20 AM
Turbo-LS's Avatar
The ball bearing helps little with initial spool but helps alot with respool in between shifts. Its nto nessesary but it sure is nicer if you can foot the bill
Old May 2, 2011 | 09:22 AM
NY GsR's Avatar
u dont need the dual bb for drag racing, get the journal and with that extra money u saved u can buy some pro1s. i love my journal 6262
Old May 2, 2011 | 11:28 AM
TheShodan's Avatar
Moderator
