Precision SC61 questions
Yes, this turbo has been talked about repeated times and I have done a search already. It seems the majority of you that run them range from a 1.8 to a 2.0 liter motor which is what the turbo was designed for. So my question is, would the sc61 60comp and t3 63a/r stage V wheel be a good turbo to use on a fully built prelude motor (bored to 2.4 liters)? Or would you recommend running the sc63 on that specific motor? I am looking for both streetability as well as power for the track. I will be happy with the mid 400's for power since my other turbo is not adequately sized to meet those needs. Thanks.
Modified by GudeH23a at 1:35 PM 8/19/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">yep, already taken care of... the turbo should be here late this week or early next week
what did you go with??
</TD></TR></TABLE>what did you go with??
Smarter than you
The Gt40 compressor wheel that is used in the SC61 is a popular wheel for not just 1.8L's but alot of 3 liter V6/I6's too. It should work really well on a 2.4L. The advantage of running it on a bigger motor is u can run a bigger exhaust side and still maintain good spool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot »</TD></TR><TR><TD CLASS="quote">Is the SC61 ball bearing??</TD></TR></TABLE>
no
no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
what did you go with??</TD></TR></TABLE>
sc61 to4e compressor .58 a/r t4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">id use the 61 </TD></TR></TABLE>
It will be perfect for ya...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 »</TD></TR><TR><TD CLASS="quote">why dont know one go with the t04s housing?</TD></TR></TABLE>
I am....SC61 .70 A/R T04S compressor .81 A/R T housing P trim.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un »</TD></TR><TR><TD CLASS="quote">just got mine installed on a stock b18b. i'm seeing full boost around 5200 rpm.</TD></TR></TABLE>
what psi is full boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">installed on a stock b18b</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by symba »</TD></TR><TR><TD CLASS="quote">what psi is full boost?</TD></TR></TABLE>
Hes running a stock b18b, so full boost is probley 8-12psi
I have yet to hear an advantage to the S housing over the E housing worth the price difference. If you know of it, let me know. I'm in the market for an SC61 and if someone can explain the true, proven difference between the two I'd be grateful.
right now it's .45 bar. but once i put the mbc on i'll be running about .55-.6 bar
right now it's .45 bar. but once i put the mbc on i'll be running about .55-.6 bar</TD></TR></TABLE>
which exhaust wheel do you have in ur sc61 ??
stage5 ( 76 trim ) or O-trim / P-trim ???
thanks
thanks
