Precision PT67 Dyno Graphs.. lets see em
Old Feb 25, 2009 | 07:28 PM
Topdawgg's Avatar
Default Precision PT67 Dyno Graphs.. lets see em
I just picked up a PT67 T4 .68 A/R for my current setup
Its an 84mm LS block
9.0:1 compression
Pauter Rods
Rc 1000s
Currently a single walbro with stock lines and stock FPR and Rail
Upgrading the fuel setup to a dual walbro setup, upgraded lines.. AEM FPR and Rail
Tial 44mm WG
Tial 50mm BOV
Precision 750 intercooler..
Supertech Valvetrain
Old setup made 493@21 psi on race gas with Crome
new setup is going to be tuned with ECTUNE
Skunk2 Pro1 Cams added as well as an AEM Meth kit
Im shooting for 600whp
I think this setup should make that Easily.. Only limiting factor would be the single disk clutch.. Currently the Competition Stage 5. Ill upgrade if needed
So Im looking for feedback from people with this turbo.. Graphs would be nice..
Curious to see similar setups and their numbers with both PUMP and race gas
Discuss..
Old Feb 25, 2009 | 09:16 PM
sweetfwdthunder's Avatar
Default Re: Precision PT67 Dyno Graphs.. lets see em
IIRC, in order for you to really benefit from the pro1's, you need a fairly large hot side for your turbo.. Other than that though, i don't see why you wouldn't be able to hit your goal. Good luck!
Old Feb 26, 2009 | 04:16 AM
Adriano's Avatar
I have the same set-up as you (pt67, 750 i/c, 1000's, tial bov and w/g) But I have edelbrock cams. My car made 690whp @ 33psi and 726whp @ 38-39psi.
Adriano
Old Feb 26, 2009 | 04:37 AM
96 GSR-T's Avatar
Made 585hp with the 67ho at 23psi with GSR cams, swapping the T3 housing this year for a 1.15 T4 Divided.
Old Feb 26, 2009 | 04:43 AM
Topdawgg's Avatar
Adriano
Wow.. impressive numbers.
whats your fuel setup?
Post the graph?
hows it spool?
Old Feb 26, 2009 | 05:47 AM
Evans-Tuning.com's Avatar
Former Vendor
Customers car using the PT67 with a .81 a/r housing: http://www.evans-tuning.com/feature_..._july2008.html
The turbo is old school, but works.
Old Feb 26, 2009 | 05:49 AM
cotorresgee's Avatar
Adriano
Killer numbers bro!!!
Old Feb 26, 2009 | 12:33 PM
Topdawgg's Avatar
Nice numbers....
Keep the graphs comin...
some damn impressive numbers.. more then I expected
Old Feb 26, 2009 | 01:15 PM
PT66Y922Rx83's Avatar
K20a2 stock bore/stroke
11.5:1 compressions
stock cams
.5mm oversize valves ported head
air to air Yonaka 3" intercooler
3" downpipe
Full-Race Turbo Manifold
PT67p trim bb.81AR to4s cover non ported shroud
Ported Type R IM w/ 75mm bdl tb
VP C16
Old Feb 26, 2009 | 01:23 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
blue is e85 red is pump made 275tq stock gsr motor
Old Feb 26, 2009 | 01:27 PM
Topdawgg's Avatar
I forgot to mention my PT67 has the vband exhaust housing and a ported shroud
I have a 4inch DP on my 35R right now that I could use, but I also have a 3inch ceramic coated DP that I was going to switch to.
The 4 inch isnt really much good to me because It goes right to a 3 inch exhaust..
Old Feb 26, 2009 | 07:03 PM
92redhatch's Avatar
impressive
Old Mar 1, 2009 | 09:11 AM
2.0 and up's Avatar
I was reading this setup before...really impressive
Old Mar 1, 2009 | 10:41 AM
Blown90hatcH's Avatar
I love that turbo. My car made 700whp/450trq at 31psi. T4, 70 trim with a .68 hot side. 2.5" IC piping. Stock TB. 3" DP. Hondata S200. ITR cams. 10:1 compression. Very simple and effective build for sure.
Old Mar 1, 2009 | 06:16 PM
mrbsponge's Avatar
and went really damn fast too, and was also very reliable and fit perfectly in the engine bay......................i miss the good ole days
Old Mar 1, 2009 | 07:00 PM
swapit's Avatar
this was my last build w/a t/3 t67h.o. new build has higher compression,bigger throttle body and a ball bearing 67
http://forums.evans-tuning.com/viewt...hp?f=38&t=5223
Old Mar 5, 2009 | 11:08 PM
Topdawgg's Avatar
I love reading this ****!!
I think Im gonna be happy with this turbo
Old Mar 6, 2009 | 05:51 AM
illassek9's Avatar
mines made 627 at 23psi.. pt67 .83 back t3 ls/vtec je 9.0.1, 81mm stock sleeves, ctr cams,fullrace manifold,3" ic piping
s300
avcr boost controller
Old Mar 12, 2009 | 12:13 PM
Topdawgg's Avatar
incredible
Old Mar 12, 2009 | 09:21 PM
Teglove2's Avatar
wow stock sleeves making 600whp+ nice! I was really thinking about getting that same 67 but I wanted a lil better spool for the street, opted for the .82 35r
Old Mar 13, 2009 | 04:07 AM
Former Vendor
The T4/T67 works really well in twin scroll configuration. If you are looking for a more response and better spool the 1.15 a/r TS turbine housing works really well.
Old Mar 13, 2009 | 05:19 AM
Adriano's Avatar
Where can you get a divided housing for the PTE pt67 bb? Thanks
Adriano
Old Mar 13, 2009 | 06:12 AM
96 GSR-T's Avatar
Adriano
ATP has them for $250 and just about anyone that sells the turbo should be able to get the housing, I will be running the 1.15 T4 this year too.... cant wait.
Old Mar 13, 2009 | 07:27 AM
Former Vendor
We order the housings through ATP turbo. They have a good amount of sizes available for the p-trim wheel.
Old Oct 20, 2009 | 02:38 PM
Topdawgg's Avatar
Long time since I originally made this thread..
I decided to pick up a divided manifold, so Im on the search for a divided housing for this same turbo.
I searched ATP, maybe i just cant find it myself...
