Precision Intercooler endtank question
Old Feb 7, 2006 | 01:29 PM
TurboEM1's Avatar
Default Precision Intercooler endtank question
Hey guys I am looking to buy a precision intercooler size 26 3/4" L x 6 1/4" H x 3 1/2" D (shown in pic).
How will this be on a 1991 CRX Si? (max 300 hp)
Will the endtanks coming out of the middle of the sides be a problem mounting?
Will the size be a problem?
Anything I should know about mounting it that may hold me up?
Is this a good intercooler?
Whats a good price for a new one?
Thanks!
Modified by TurboEM1 at 3:52 AM 2/8/2006
Old Feb 7, 2006 | 06:00 PM
TurboEM1's Avatar
Default Re: Precision Intercooler endtank question (TurboEM1)
any1 use this intercooler?
Old Feb 7, 2006 | 06:15 PM
g2turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I am looking to buy a precision intercooler size 26 3/4" L x 6 1/4" H x 3 1/2" D (shown in pic).
uh?
not unless you ziptie the charge pipes to it
no
don't ziptie it, make brackets
yes
Call Precision or look on the FI sponsor board
Thanks!
Modified by TurboEM1 at 3:52 AM 2/8/2006</TD></TR></TABLE>
Old Feb 7, 2006 | 06:21 PM
HamiltonRex's Avatar
Default Re: Precision Intercooler endtank question (g2turbo)
I just installed this IC on my crx.
Fits really good, full bumper beam, bumper needed some shaving. I just cut the tab off the bottom of the beam.. centered it, and made to tabs on the bottom of the beam and bolted it up.
Old Feb 8, 2006 | 04:19 AM
TurboEM1's Avatar
Default Re: Precision Intercooler endtank question (HamiltonRex)
you have any pics of the mounting?
Old Feb 8, 2006 | 04:56 AM
AspectIndustries's Avatar
Just do it!
Old Feb 8, 2006 | 05:53 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">any1 use this intercooler?</TD></TR></TABLE>
Yes alot of people use Precision intercoolers and yes they are good products. I am currently using the 600hp model and the intake temps on the dyno during a hot summer day started around 95* and by the end of the pull they were 82* I paid $350 for the 600hp model brand new.
Old Feb 8, 2006 | 06:29 AM
Chris22215's Avatar
Default Re: Precision Intercooler endtank question (Dunc)
^ Exactly. I'm running the 600hp one too. precision makes some awesome stuff, they're even bar and plate.
Old Feb 8, 2006 | 10:35 AM
TurboEM1's Avatar
Default Re: Precision Intercooler endtank question (Chris22215)
Thanks for all the replies.
One last thing. Is the intercooler big enough? Should I get one rated for more horsepower? It seems fairly small but I dont think my setup will be making over 300whp. (t3/t4 60trim .63 a/r on 8lbs most likely)
Modified by TurboEM1 at 8:45 PM 2/8/2006
Old Feb 9, 2006 | 02:11 PM
Dunc's Avatar
BCICAN
yea it might be under 300 @8psi, but what happens when you get the boost bug like everyone else and go to 15psi.....
Old Feb 9, 2006 | 03:53 PM
You should be ok with that size.
They under-rate their stuff a bit for worstecase senario (350hp one holding 350whp in a very hot climate).
There is a fine line between where it looses its efficency and you get negative effects like pressure drop, its always important to choose the right size intercooler.
The IC will work very well for you, plus it isnt easy at all fitting them under EF bumpers without destroying the bumper or beam, or doing alot of custom work to get it to sit where you want it.
Goodluck, ill try and get some pics shortly.
Sic_DA_Nine
Nov 27, 2007 02:46 AM
integranator
Sep 28, 2007 08:06 AM
almostboostedgsr
Feb 10, 2007 09:39 PM
LBR92DA-T
Feb 10, 2004 09:44 AM
lsturborex
Apr 29, 2003 08:15 PM
