which precision injectors?
Old May 24, 2004 | 07:19 AM
graphic's Avatar
Default which precision injectors?
which ones for my set-up?
built h22
aem ems
t3/t4 h-3 compressor trim,.63a/r w/ stage 3 exhaust
going to be running 18psi
and i am guesstimating i will make 300-350whp
i was think of going with the 780's
also will they clip in to the stock harnesses??..or do i need adapters???
Old May 24, 2004 | 06:32 PM
DRIVENRacing's Avatar
thats low hp for 18 psi man.... sohc make that around 14-15 psi...
Old May 24, 2004 | 07:06 PM
z6's Avatar
z6
SOHCz OWN!
Old May 24, 2004 | 07:09 PM
B18 CYA's Avatar
no they dont
Old May 25, 2004 | 12:32 PM
z6's Avatar
z6
go with 780s
Old May 25, 2004 | 12:51 PM
b16ahybrid's Avatar
Default Re: which precision injectors? (graphic)
For that hp, the 780's will be fine.
Old May 25, 2004 | 12:55 PM
Griffin@Camtech's Avatar
780cc will be the best bet but you will be making a hell of alot more HP then that
Old May 26, 2004 | 07:12 AM
graphic's Avatar
Default Re: which precision injectors? (Stickdeath)
i am going to go w/ saturated rc injectors 750cc
i just don't want to run out of injector...
Old May 26, 2004 | 09:01 PM
b16ahybrid's Avatar
you should be good, if anything you an raise your fuel pressure a little to compensate for the the extra noost. Doubt you''ll neeed to though
Old May 26, 2004 | 09:35 PM
TheShodan's Avatar
Moderator
Precision sells injector clips that are OBD0 that work with those injectors, they're about $62 but they plop right in there.
broadheadjohn
Mar 28, 2007 04:20 PM
tweekerz
May 3, 2006 07:26 AM
S2KP
Jul 2, 2004 10:28 PM
servion
Jan 20, 2004 02:16 PM
sparq
Jan 7, 2003 08:53 AM
