precision 6265/6765
Old Sep 9, 2010 | 06:43 PM
v.i.gsr's Avatar
Default precision 6265/6765
looking to purchase a billet 6265 or 6765 v-band housing turbo, read that the housings are 2.5" for the d/p.. can anyone confirm if this is true..
Old Sep 9, 2010 | 06:50 PM
B20luda's Avatar
Default Re: precision 6265/6765
mine is a 2.5 outlet 4 bolt, i use a vband adapter though
Old Sep 10, 2010 | 12:17 AM
Zer0_SpeedWorks's Avatar
^^^what he said...
vband=3in if you picked that option
Old Sep 10, 2010 | 08:09 AM
twkdCD595's Avatar
Thats not true.
I have a 6265 V-band oulet unit... it is definately not a true 3" vband size by the industry standard definition. If you buy a standard 3" V-band clamp it will be too big.
Not 100% sure on the 6765 V-band outlet unit since its been a few since I messed with one on a friends car, but I am pretty sure they are done the same way as the 6265 V-band outlet sizing.
Old Sep 10, 2010 | 08:39 AM
RealStreet's Avatar
Correct you have to use the Precision Flange/Clamp as it is not a true 3". Whoever you get the turbo from should be able to supply the right parts. If you need anything let me know we are a dealer.
Old Sep 10, 2010 | 09:18 AM
v.i.gsr's Avatar
I bought a manifold and d/p from SLS, and its a v-band ram horn and 3" v-band d/p and was going to purchase either the 6265 or 6765.. Do u think I would run into any problems with the 3" of the d/p and the housing for the turbo..
Old Sep 10, 2010 | 09:22 AM
PSI2HI's Avatar
Former Vendor
If the turbine inlet is v-band then the turbine outlet uses a 3" v-band. If the turbine inlet is a std T3 then the turbine outlet uses a 2.5" v-band or 4 bolt.
Old Sep 10, 2010 | 11:11 AM
v.i.gsr's Avatar
ok thanks for the info..
Thanks for the manifold and d/p also, the work on them is top notch...
that-guy
Welding / Fabrication
10
Jan 2, 2012 06:10 PM
Lewy. Dee Ayy
Oct 18, 2011 06:25 PM
velisma
Mar 8, 2011 11:25 AM
NAEGH22
Jun 22, 2010 09:52 PM
85
Feb 22, 2007 06:59 PM
