precision 5431e billet cea, anyone using it?
Old Aug 24, 2011 | 08:19 PM
racebum's Avatar
Default precision 5431e billet cea, anyone using it?
earlier today i was on my way to the post office to mail off a compressor housing for ceramic coating when it dawned on me it would be worth asking precision if it were possible to trade up turbos since the 5431b that i had was new. well, with a little talking and some debating i sent back the 5431b which was a v-trim for their new 5431e cea
http://www.precisionturbo.net/produc...--5431E-CEA/58
anyone use one of these yet? curious where they come up and what they do dyno wise
Old Sep 16, 2011 | 04:44 AM
OMG B16's Avatar
Default Re: precision 5431e billet cea, anyone using it?
I have one sitting in my room for my d16 turbo build. Bump for more info.
Old Oct 1, 2011 | 06:11 PM
Cole D's Avatar
bump for any information
Old Oct 2, 2011 | 04:25 PM
Natural Aspirations's Avatar
L
Old Nov 19, 2011 | 05:03 AM
brxboy's Avatar
Dont mean to bump this old old **** thread but i need to know cause i just bought one my self.
Old Nov 19, 2011 | 12:01 PM
racebum's Avatar
most the testing has been done on the str4. it should behave like a 50tim + a few more hp due to flowing 50/lb min.
Old Nov 22, 2011 | 06:53 AM
brxboy's Avatar
http://www.youtube.com/watch?v=feAH1wyQsck
Old Jun 26, 2012 | 02:47 AM
Cole D's Avatar
Did not want to create a new thread does anyone have any experience with this turbo?
Old Sep 11, 2012 | 12:23 PM
Bizzle5OH3's Avatar
I see you posted this three months ago, but ill try and help you out
I have a B16A2 CP pistons, Eagle rods, king bearings, port and polished head with a full supertech valvetrain and GSR cams.
Im running the precision 5431 with a .63 A/R on a ramhorn manifold with 3 in DP and full 3 IN exhaust.
My numbers on 19 PSI were 360WHP with 270WTQ. However my headgasket was failing on the dyno ( exhaust was getting into the coolant system and overheating it ) so my numbers might actually be higher now.
The B16 is bored to 81.5mm and I see the full 19 PSI around 5K RPMs with the VTEC set at 4800 RPMs
Hope this helps
Old Sep 11, 2012 | 05:34 PM
wantboost's Avatar
Who is Mr Robot?
i try to stay far away... too many failures for my liking and precision never wants to replace them... constantly sighting "oil contamination" as a cop out to skip warrantying the units..
Old Oct 20, 2012 | 06:28 PM
Lazysk8r2's Avatar
I made 417WHP AND 315WTQ with the 5431cea @17lbs
Setup:
B18c1 81.5
9:1 wiseco pistons
eagle rods
B16a2 head CTR cams
SPA cast top mount
3"dp
2.5" IC piping
68mm TB
skunk2 intake mani
switching to e85 and a mini ram this winter and see what i can make. Im wondering how much hp i can take the turbo to.
Old Oct 20, 2012 | 06:45 PM
ek9.5's Avatar
bump waiting for summer to get dyno tune on a 5431 cea on a e85
Old Oct 9, 2014 | 07:10 PM
SI RICKO's Avatar
B18b crower head package,crower stage3 404 cams,wiseco 8:6.1 pistons,Golden eagle fuel rail,Hasport mounts, BDL cam gears,Precision 780cc injectors,ACL race bearing,blox vac box,blox plenum, goodspeed turbo mani, s.o.p. i/c kit ,Precision 5431 billet 50 trim turbo, BLD block guard,ARP head studs And rod bolts,golden eagle H rods,Hondata plenum gasket,Custom GO-power screamer pipe,-16 AN moroso breather can,Aem water/meth kit shooting 500cc's, Running Neptune RTP with demon board. I made 450 on 27 pounds.
boots89
Feb 1, 2012 05:33 PM
pitchblacksvt
Jul 8, 2011 05:33 PM
dbang003
Oct 29, 2010 03:05 PM
WhiteEJCoupe
Jun 30, 2010 10:38 AM
b18bturbo
Oct 13, 2005 07:59 AM
