precautions...taking a 5 hr. trip while boosted
Old Apr 1, 2003 | 07:45 PM
ridnmyhonda's Avatar
Default precautions...taking a 5 hr. trip while boosted
what should i do when traveling a long distance...i'm at 7 psi. anything i should do or watch for or do...thanks
Old Apr 1, 2003 | 07:47 PM
boosted hybrid's Avatar
Default Re: precautions...taking a 5 hr. trip while boosted (ridnmyhonda)
Watch egt's. Other than that, there is nothing that I can think of. Oh, be wary of the gas you buy long distances away. Sometimes its lesser grade and you are paying for 91,93,94, etc.
Old Apr 1, 2003 | 07:48 PM
Daniel's Avatar
i traveled 2 hours on my setup at 5.5 psi, took a 1.5 hour HARD drive through the mountains, and then took another 2 hour trip back home. i'd just suggest that will cruising on the freeway, don't boost and take it easy. it's not like you're going to be boosting while driving on the freeway, anyway ... unless you need to make a quick pass or something.
Old Apr 1, 2003 | 08:01 PM
DeepSi's Avatar
Default Re: precautions...taking a 5 hr. trip while boosted (Daniel)
i jus did two 26+ hour trips and there is not much to worry about. the only time you will be boosting is going uphill and accelerating offramps. just change your oil and check your fluids before you leave. others keep any eye on your guages and when you stop for gas let the car idle to cool down and check for leaks. You should be fine
Old Apr 1, 2003 | 08:04 PM
Default Re: precautions...taking a 5 hr. trip while boosted (DeepSi)
thanks guys
Old Apr 1, 2003 | 08:36 PM
accordexchange's Avatar
i don't think it would hurt to keep some extra fluids in the trunk or something just in case you might need it... think of something like a first aid kit for your boosted car...
Old Apr 1, 2003 | 08:49 PM
DeepSi's Avatar
Default Re: precautions...taking a 5 hr. trip while boosted (accordexchange)
Yeah i keep a box of oil in my car, and on log trips i bring some bottle water and anti-freeze. common tools also. AND Duct tape for emergencies, it can fix almost anything temporarly, enough to get to a shop i hope
Old Apr 1, 2003 | 09:10 PM
Joseph Davis's Avatar
I usually raise hell and play with the boost on road trips. To and from PA (7 hours) twice; Jax, FL, (5 hours heh) once; Raleigh (4 hours) twice; Fayettenam (4 hours) twice; Knoxville (1 hour) six times; Charlotte (1.5 hours) three times; and Atlanta (3.5 hours) once since I've been turbo.
7 psi B18B in an 1800 lb CRX HF makes for amusing looks on LS1 Camaro owner's faces. Roadtrips are good.
MalcolmV8
Jan 6, 2013 10:43 AM
MAFDARK
14
May 27, 2009 01:18 PM
zccrx
Nov 9, 2007 11:20 AM
freeplay
Oct 13, 2002 07:11 PM
