Power Steering with forced induced B16a
Old Mar 4, 2016 | 06:12 PM
Har2Core's Avatar
Default Power Steering with forced induced B16a
Hello guys I have a question I need answered I have a b16a I am planning on putting in my 97 CX hatch it will be a turbo build just wondering if any of you have had any issues with keeping your power steering if so how did you go around keeping it.
Cheers
Colin.
Old Mar 4, 2016 | 07:33 PM
TheShodan's Avatar
Moderator
Default Re: Power Steering with forced induced B16a
Very simple.
Get an exhaust manifold that 1) fits for your power goals and use with the size turbocharger you need, and 2) doesn't eliminate the power steering bracket completely. So that means no using top mount manifolds, and if using a kooks-style manifold (aka "Ramhorn") only trim the power steering bracket and use a shorter bolt to keep it in place.
Old Feb 18, 2017 | 03:17 PM
IN VTEC's Avatar
I did exactly this and the result is I don't have to worry about diverting my attention to steering the car and can focus on simply driving it.
I do underdrive the pump with a larger pulley since the motor turns 8800rpm as a precautionary means of sparing the pump. It has survived 7000 miles and 30+ 1/4 mile passes.
The manifold is a Full-Race Prostreet T3/44mm gate.
Old Feb 18, 2017 | 03:24 PM
Har2Core's Avatar
Thank you guys input is appreciated, IN VTEC what larger pulley did you use ?
Jason Nucom
Dec 8, 2012 09:19 PM
b16a3delsol
Feb 20, 2008 06:01 AM
