Power loss vs. compression reduction : Rule of thumb?
Old Jan 16, 2004 | 08:49 AM
JO's Avatar
JO
Default Power loss vs. compression reduction : Rule of thumb?
Has anyone ever figured out a rule of thumb or something similar for the power loss you get when you drop the compression ratio? Does it work proportionnaly for boost too?
For example, I have a B16 with 9.0:1 compression, down from 10.2:1 stock. Bore is the same. Assuming it makes ~140whp stock, how much do you think it would make now, and can you assume a similar reduction percentage when boosted from what it would do if it had stock compression still?
I hope it makes sense! Thanks!
Old Jan 16, 2004 | 10:26 AM
Cyphear's Avatar
you'll get pretty close if you do the ratios between the two multiplied by the original. so (9.0/10.2)*140 = 123whp
Old Jan 16, 2004 | 10:42 AM
Overblown-Teg's Avatar
Default Re: (Cyphear)
Plus the extra 5psi you can run on pump gas now is 127+5*18=217..
Old Jan 16, 2004 | 10:43 AM
808b18c1boosted's Avatar
you will be down about 2.9 % hp
Old Jan 16, 2004 | 11:53 AM
JO's Avatar
JO
Default Re: (808b18c1boosted)
lol wtf?!
Old Jan 16, 2004 | 11:56 AM
Default Re: (JO)
Was that @ me? If so what I mean is the small amount of power you will lose by droping compression will more than make up with the higher boost you can run..
Old Jan 16, 2004 | 12:11 PM
JO's Avatar
JO
Default Re: (Overblown-Teg)
No that was for b18c1boosted. The intent of this thread was to get an idea as to what kind of difference you will observe on 2 similarly boosted set-ups @ the same psi with the only difference being a compression drop. I know I can crank that sucker up.
Old Jan 16, 2004 | 12:16 PM
kpt4321's Avatar
If you're going to leave the boost at the same place, then why would you lower the compression?
Old Jan 16, 2004 | 12:17 PM
Default Re: (JO)
Pick up the new drag sport mag. it talks about forged pistons. it has a chart and i baisically says if your original comp was 10:1 and you drop it to 9:1 you will lose 2.8% at the some boost level but you get a larger margine in tuneing error.
Old Jan 16, 2004 | 12:20 PM
Default Re: (kpt4321)
exactly
Old Jan 16, 2004 | 12:40 PM
JO's Avatar
JO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to leave the boost at the same place, then why would you lower the compression?</TD></TR></TABLE>
Argggh! I was curious that's all, that was an example, I just wanted to have an idea of what kind of power reduction per point of compression drop you'll typically see.
b18c1boosted, that's exactly what I was looking for, thanks I'll look up the mag.
b18c5turbo
Jul 15, 2005 02:51 PM
Soon_2b_evil
Nov 16, 2003 07:41 PM
HX_Guy
Dec 6, 2001 03:24 PM
Halo
Nov 12, 2001 01:45 PM
