power FC on prelude PROBLEMS
Old Oct 1, 2008 | 04:33 PM
2SLO's Avatar
Default power FC on prelude PROBLEMS
hey guys. i have a 97 prelude at work with a power FC and 550cc precision injectors on it. When i start it, it will idle (rough) and when i give it throttle, it dies. tps voltage is perfect.. any ideas?
Old Oct 1, 2008 | 05:35 PM
Drew Peacock's Avatar
Is it tuned to suit the injectors?
Old Oct 1, 2008 | 05:45 PM
2SLO's Avatar
Default Re: (Drew Peacock)
yeah, its an h22 basemap set for 550s
Old Oct 1, 2008 | 07:34 PM
Boost control option turned off?
Old Oct 1, 2008 | 07:53 PM
TheShodan's Avatar
Moderator
Did you keep your stock Map sensor AND the other pressure sensor, or did you remove it, and only think you were to run a GM 3 bar?
Old Oct 1, 2008 | 09:26 PM
2SLO's Avatar
Default Re: (TheShodan)
it JUST has the stock map sensor...
Old Oct 2, 2008 | 05:05 AM
2SLO's Avatar
Default Re: (2SLO)
anybody??
Old Oct 2, 2008 | 07:07 AM
TheShodan's Avatar
Moderator
Default Re: (2SLO)
Since you changed injectors, you need to change and tune the air/fuel trim on the power FC by way of an FC datalogit, or go to a Power FC excel tuner that has the edit software. You'll also need the boost kit and solenoid so it can go PAST the 11psi point. Did you purchase this new or used, and if so, Which one did you purchase? They did not make one for the prelude, but people integrate other models into the ones they weren't designed for.
Old Oct 2, 2008 | 08:08 AM
2SLO's Avatar
we are an authorized power excel shop. this is for idle, not for 11psi.
Old Oct 2, 2008 | 01:12 PM
PrecisionH23a's Avatar
Default Re: (2SLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2SLO &raquo;</TD></TR><TR><TD CLASS="quote">yeah, its an h22 basemap set for 550s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2SLO &raquo;</TD></TR><TR><TD CLASS="quote">we are an authorized power excel shop. this is for idle, not for 11psi. </TD></TR></TABLE>
Uhhh.... maybe you should tune the car??? Base maps are just base maps. They don't always allow the car to drive flawlessly.
Old Oct 2, 2008 | 01:30 PM
TheShodan's Avatar
Moderator
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Uhhh.... maybe you should tune the car??? Base maps are just base maps. They don't always allow the car to drive flawlessly.</TD></TR></TABLE>
Exactly. I don't mean to sound harsh, but if you an authorized Excel Tuner/ dealer, then really, we're the last people to ask to tune this. Excel dealers have to go to california in order to learn the specifics of this system. I deal w/ Excel dealers all the time for my Power FC tunes and you don't seem to exhibit the behavior of those who attended those classes and were certified. You may be able to SELL Power FC, but that doesn't mean you're an EXCEL distributor.
Sounds like an injector issue that you need to tune out, as well as get that boost kit.
Are you using the B18C or B16B system to tune?
Modified by TheShodan at 7:02 AM 10/3/2008
Old Oct 2, 2008 | 02:20 PM
MiraiZ's Avatar
I suspect that its the injector size...check it again.
Also, are you using a PFC from a B16b of B18c engine?
Old Oct 2, 2008 | 10:30 PM
LastGenEK's Avatar
Default Re: (MiraiZ)
Thos Injectors i believe need a resistor box! If you dont have one it will run real rich!
Old Oct 3, 2008 | 08:14 AM
Default Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">Thos Injectors i believe need a resistor box! If you dont have one it will run real rich!</TD></TR></TABLE>
Precision doesn't sell a sport compact 550cc (low imp) injector unless it's the sport compact mitsibushi fuel injector. They sell 525cc's (high imp) and 580cc's (low impedance) which are the ones designed for honda's. If he is running the 525cc's (high imp) then he does not need a resistor box. If he is running the mitsu style injector, then he needs a resistor box.
Regardless, if he did in fact tune the car for 11psi he should be able to tune it for idle if he is a certified dealer for this product. TheShodan pretty much summed it up.
Old Oct 3, 2008 | 08:42 AM
LastGenEK's Avatar
Regardless, if he did in fact tune the car for 11psi he should be able to tune it for idle if he is a certified dealer for this product. TheShodan pretty much summed it up.</TD></TR></TABLE>
Thank you for the info
Old Oct 4, 2008 | 07:46 AM
2SLO's Avatar
power FC was [freak]ed up. internaly
Old Oct 4, 2008 | 09:29 AM
TheShodan's Avatar
Moderator
Default Re: (2SLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2SLO &raquo;</TD></TR><TR><TD CLASS="quote">power FC was [freak]ed up. internaly </TD></TR></TABLE>
Ah, there's the rub. Glad you were able to switch units and verify.
Old Oct 4, 2008 | 05:35 PM
2SLO's Avatar
me too. after being hated on in this thread
Old Oct 4, 2008 | 05:57 PM
SovXietday's Avatar
Default Re: (2SLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2SLO &raquo;</TD></TR><TR><TD CLASS="quote">me too. after being hated on in this thread </TD></TR></TABLE>
Honestly, there are soooo many better options as far as tuning systems go when it comes to Honda Power FC is the last thing we deal with in here. *shrug*
Old Oct 5, 2008 | 07:03 AM
2SLO's Avatar
Default Re: (SovXietday)
our customer wanted it, were a dealer, so we sold it to him.
Old Oct 5, 2008 | 05:18 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">
Honestly, there are soooo many better options as far as tuning systems go when it comes to Honda Power FC is the last thing we deal with in here. *shrug*</TD></TR></TABLE>
Hehe. had Power FC tuned well on 2 personal cars for over 6 years, and not one issue. Many people that have had this as a solution has been satisfied. Simply because it doesn't cater to fall within a bandwagon for drag racers (2 step, launch control, boost by gear) doesn't make it a bad system by any means. There are those w/ both NA and Boosted setups that work consistently well with the Power FC on this forum, that perhaps you haven't paid any attention to.
Old Oct 6, 2008 | 06:17 AM
2SLO's Avatar
afc hack ftw!
Old Oct 6, 2008 | 08:09 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Hehe. had Power FC tuned well on 2 personal cars for over 6 years, and not one issue. Many people that have had this as a solution has been satisfied. Simply because it doesn't cater to fall within a bandwagon for drag racers (2 step, launch control, boost by gear) doesn't make it a bad system by any means. There are those w/ both NA and Boosted setups that work consistently well with the Power FC on this forum, that perhaps you haven't paid any attention to.</TD></TR></TABLE>
Hmm, maybe I worded what I said poorly.
I've used Power FC plenty of times before, it's a great system. But I've only ever used it on SR/13B/etc powerplants. Mostly Nissan/Mazda world. I've never tuned with it, just put it in cars but you understand what I mean. I've been on Honda-tech for a good amount of time now, and I still rarely see people using the Power FC, and even fewer people who actually know anything about it.
Which was kinda my point and your point earlier, this is seriously the last place to ask a question about the system. That's all.
Old Oct 6, 2008 | 11:40 AM
TheShodan's Avatar
Moderator
Ah. I see where you're coming from now. Based upon that statement, I would tend to agree. Now that you've worded it that way, it is more clear now.
nokehockey20
Jun 29, 2016 08:24 AM
BMO98GSR
Engine Management and Tuning
11
May 27, 2008 04:09 PM
Mr. LS VTEC
Sep 20, 2006 09:22 AM
Phoenix1
Sep 15, 2005 08:09 PM
TurboT
Apr 3, 2002 04:27 PM
