Post your Boosted high compression poor mans type r
Old Feb 2, 2016 | 06:55 AM
K20.ek's Avatar
Just want to see if anyone has boosted a stock internals with 11.0cp and have any succes with low boost with about 300whp or the max with stock internals.
My setup in a eg hatch
Gsr long block
Usdm type r Pistons
Ctr cams
Super tech valve train
Type r intake valve
Ferrea exhaust valve
Sk2 pro series manni
Bwks adjustable cam gears
Tuned in hondata s300v3
I had boosted a stock jdm ls motor with 1000cc rc injectors and t3/4 70ar Garrett turbo and made 290whp on 10psi.
I'm goin to be reusing my injectors and turbo setup for this poor mans type r with gsr head and wanting to know what's a safe powee range? I'm not looking for mega power just some wher near 300whp
Guess no one has done or too high cp.
Old Feb 3, 2016 | 06:31 AM
bergercurtis's Avatar
Default Re: Post your Boosted high compression poor mans type r
Muckman and a few others have done some nice higher compression builds. I don't think many of them are eager to measure up or even active regularly.
Old Feb 3, 2016 | 06:38 AM
TheShodan's Avatar
Moderator
In addition, this has been addressed before. K20.ek can easily ask the questions needed without this redundancy or head out throughout the forum and search for these individuals and their setups.
But suffice it to say.. Yes, it has been done quite well, and with reasonable success rates.
Old Feb 3, 2016 | 11:37 AM
NotARaCist's Avatar
I never narc'd on nobody!
"too high cp"? You mean too high CR?
11:1 is easy on 93 and a competent tuner. Seriously OP, do some digging. Go read other people's build threads. If you're going to make a "post your..." thread, being so obscure and specific really is counter to what you want, and hint: There's already an LS/VTEC thread.
Old Feb 3, 2016 | 12:16 PM
K20.ek's Avatar
Yes I have search and found a lot using forged internals and some saying it's too high of a compression to boost and to some saying to lower compression, I wanted to see someone that actually has done it on stock internals with gsr head and have no problem boosting high compression poor mans type r similar to the setup I have.
Old Feb 3, 2016 | 12:27 PM
NotARaCist's Avatar
You have a lot of learning to do, young grasshopper. Compression does not matter, within the limitations of the fuel you have available and the competency of your tuner. If you can only get 91 pisswater, or if you plan on trusting Joe Blow out under the shadetree to tune your car, then yes, 11:1 is too high. If you have 93 or E85, and have a tuner that actually knows what the **** he's doing, then it's entirely doable up to the standard limitations of any B series.
Old Feb 3, 2016 | 12:53 PM
K20.ek's Avatar
I have 93 here and only run 93. Can someone send me a damn link to the same setup I have so I can see some setups and get some ideas, I tried every way possible to find a similar setup and can't find ****.
Old Feb 3, 2016 | 12:59 PM
NotARaCist's Avatar
You know how I know you're lying? Because I found the LS/VTEC thread on the second page. All you had to do was click to the second page, and you would have found it. You also would have found two other build threads on the way there - one about a high compression B20V, and the other an LS/VTEC with an 800 horsepower goal. They're all right there. You just need to read.
Old Feb 3, 2016 | 01:03 PM
K20.ek's Avatar
Ok. I was actually typing in STOCK internals type r boosted and ls vtec with gsr head and poor mans type r turbo build. But I'll check it.
Old Feb 3, 2016 | 02:02 PM
Aradin's Avatar
Premium Member
Are they not teaching kids how to google in school nowadays? Try to dumb down your search terms to something a bit more broad and you may find what you're looking for. I did ONE search and found tons of relevant information. NotARacist pretty much provided you with everything you wanted to know anyway.
Old Feb 3, 2016 | 02:10 PM
K20.ek's Avatar
Shut ur *** up and kick rocks idiot I'm not a kid I'm probably old as you. If you ain't got no setup to post then don't post of my ****. And I am searching what he posted and I'm reading and have yet to find a STOCK setup with gsr head similar to mine.
So kick rocks queer.
Old Feb 3, 2016 | 02:16 PM
Aggression's Avatar
Well that about wraps this up, I guess. Good luck with your build.
Old Feb 3, 2016 | 02:17 PM
Aradin's Avatar
Premium Member
Ahh. So now it's clear why you're having trouble. I wasn't sure before but now I'm positive that there's a clear lack of intelligence. If you can't learn how to google you probably shouldn't be attempting to add a turbo setup to an automobile. Good luck with your future boat anchor of a B series kiddo.
Old Feb 3, 2016 | 02:21 PM
NotARaCist's Avatar
Why did I even bother helping you. This is why the regulars get jaded. This is why we tell people to get fucked and go read the stickies. I hope a mod comes down hard on your incomprehensibly stupid ***.
Old Feb 3, 2016 | 02:30 PM
K20.ek's Avatar
y'all suck *** anyways. I've been building n/a Bseries enginesfor 4yrs all from googling and reading on here, all I'm trying to do is go boost high compression on stock internals and get more info since I'm new to boost and only had a Ls boosted on low compression. All y'all say is search search search... I search all the time when I need to know something and the one time I can't find nothing y'all just act like jackasses. One simple post of setup to what I want to find is simple enough so I can go about my way.
Old Feb 3, 2016 | 02:34 PM
TheShodan's Avatar
Moderator
Old Feb 3, 2016 | 02:36 PM
K20.ek's Avatar
I don't give a ****. All this **** is about dumbasses who can't provided info just as my post stated.
Post the stock setup High compression similar to mine I don't need all this bullshit info well I seen him do this or they did this...
Old Feb 3, 2016 | 02:40 PM
NotARaCist's Avatar
I just told you where you could find a metric shitload of setups. Why are you still here shitposting, and not reading through those threads?
K20.ek's Avatar
How the hell did you help me? Please... telling me to search ls/vtec is not similar to my build. My post stated I'm using a GSR LONGBLOCK.. NOT NO LS BLOCK or anything like that.
I have been reading and the other idiot up ther started posting dumb ****. I just said that I took ur info and started reading on Ls/vtec and YET to find one. I'm still goin at it. I don't know y u being a hardass on me when I was taking ur adivise and directing my comments to the other idiot who decide to post on the time I'm looking up info
Old Feb 3, 2016 | 02:45 PM
NotARaCist's Avatar
Here ya go, a second time. Do I need to post it a third time for you to unfuck yourself and put in a modicum of effort?
Old Feb 3, 2016 | 02:52 PM
AZ_CIVIC's Avatar
Why not call a reputable tuner or shop and ask them the couple concerning questions you have and see what they say?
K20.ek's Avatar
Damn must be that time of the month again for you guys... Hahaha
Thanks for the advice I will take that in to consideration.
Old Feb 3, 2016 | 02:57 PM
whited's Avatar
CRX God
Yo **** these guys. Your setup should be able to handle up to 20 psi easily. No worries man, just crank up the boost!
Old Feb 3, 2016 | 03:04 PM
Geis's Avatar
I almost spit my water on my Laptop when I read his response to Aradin LOL!
He called him a queer, guys, and said 'yall' too
Honestly, I can't tell if this guy's straight up trolling or not. He's either trolling, or some redneck who got ostracized from the pickup crowd so resorted to hondas to try and be different rofl
Old Feb 3, 2016 | 03:28 PM
K20.ek's Avatar
Damn more pms women... You sure u not spitting something else out? You came out and notice the word queer so you should be one of them. Lmao
Just come out the closet already those words offended you and wasn't directed towards you. Your name fits you too hahah geis ( sounds like gays ) hahahah wtf
