poss bad ring on my s2k
Old Apr 7, 2006 | 07:31 AM
GDM Ap1's Avatar
Default poss bad ring on my s2k
Car has 44k on it never boosted before
Old Apr 7, 2006 | 07:43 AM
Dunc's Avatar
BCICAN
Default Re: poss bad ring on my s2k (GDM Ap1)
ooooook? So do you have a question or are you just stating that you might have a bad ring?
Old Apr 7, 2006 | 07:53 AM
GDM Ap1's Avatar
Default Re: poss bad ring on my s2k (Dunc)
ah sorry it didnt copy it
Basiclly I have the head off the car and hit it with some wd40 to keep it from coroding now last night I had a lil puddle in it. This morn its gone. Could it be the rings arent expanding in that cylinder due to it not running, or the wd is so thin?
Old Apr 7, 2006 | 11:01 AM
drintegra's Avatar
put engine oil in each cylinder, the same amount and it will prevent corrosion and let you know if there is a problem. If one cylinder leaks more then the others then boom rebuild with some pistons and boost to like 500hp . When I say put oil in each cylinder I mean put like a cup of oil in there even with the other cylinders. Since it is just sitting there. Do not rotate it though. good luck
Old Apr 7, 2006 | 11:19 AM
GDM Ap1's Avatar
Default Re: poss bad ring on my s2k (drintegra)
Well I did that earlier and still leaking on that one cylinder.... I was also told that because the motor is cold it could leak down a lil bit. Now the other thing is it never smoked before I disassembled and never felt like there was a problem..
badream20
Apr 24, 2008 04:31 PM
Reza^
May 22, 2007 10:24 AM
trunks1001
Jun 3, 2006 12:22 AM
SiRkid
Jan 4, 2005 06:34 PM
mz3bo
Jul 6, 2003 09:03 PM
