Poll: Which Standalone..
Old Dec 4, 2002 | 11:08 PM
  #26
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Poll: Which Standalone.. (delvtecsol)
good reply...
Now, my question is, how does AEM deal with boost? will i still need a missing link?
No, its a stand alone. The missing link tricks the ecu into seeing boost. Now, with the EMS you want it to see boost. But if you want to run more than 11psi, you need to replace your stock map with a 3 bar map sensor.
Old Dec 4, 2002 | 11:45 PM
  #27
KStuned's Avatar
Default Re: Poll: Which Standalone.. (Arturbo)
AEM EMS
So many options, GREAT customer support, free constant product improvement (new version updates), etc.
Old Dec 5, 2002 | 01:21 AM
  #28
MiraiZ's Avatar
Default Re: Poll: Which Standalone.. (BoostinDC2)
Apexi Power FC
Old Dec 5, 2002 | 01:25 AM
  #29
BoostinDC2's Avatar
Default Re: Poll: Which Standalone.. (MiraiZ)
also the FC-Datalogit is out now so you can tune your Power FC without a power excel dealer.
Old Dec 5, 2002 | 03:18 AM
  #30
ninesecrx's Avatar
Im ghetto like Newport Cigarettes...I think you should run the old school DFI gen 6.
Old Dec 5, 2002 | 03:29 AM
  #31
420aNT's Avatar
Default Re: Poll: Which Standalone.. (ninesecrx)
Aem Ems
Old Dec 8, 2002 | 11:15 PM
  #32
pissedoffsol's Avatar
25 Year Member
Default Re: Poll: Which Standalone.. (18gTeg)
ttt... still looking for some votes/comments on this one..
thanks
Old Dec 9, 2002 | 05:18 PM
  #33
12SecHatch's Avatar
i hear aem isnt as easy as they make it sound to be
Old Dec 9, 2002 | 05:47 PM
  #34
Mase's Avatar
Default Re: Poll: Which Standalone.. (12SecHatch)
its not if you dont know how to Properly operate a computer
Old Dec 9, 2002 | 09:59 PM
  #35
25 Year Member
Default Re: Poll: Which Standalone.. (Mase)
im a computer nerd- so i dont think will be an issue...
is there a demo of AEM's software anywhere?
Old Dec 9, 2002 | 10:07 PM
  #36
InfamousRS's Avatar
I keep hereing there is...but I cant find it on the AEM site...does anyone have a link to it?
Old Dec 10, 2002 | 04:29 AM
  #37
turbotypeR@SPEC's Avatar
25 Year Member
power fc!
Old Dec 10, 2002 | 09:13 AM
  #38
slowcivic's Avatar
New User
I run a SpeedPro Bank-To-Bank Unit. Its in your budget, its easy to utilize. Check it out. http://www.fuelairspark.com/catalog/banktobank.asp
Old Dec 10, 2002 | 12:49 PM
  #39
Spunkster's Avatar
Something new with the Hondata thay may change a few minds is the option of a g-sensor that will allow you to get skidpad readings as well as dyno results. Check out the Hondata website for more details.
http://www.hondata.com/gsensor.html
Old Dec 10, 2002 | 06:46 PM
  #40
redline201's Avatar
Default Re: Poll: Which Standalone.. (Spunkster)
is hondata really a standalone????
Old Dec 11, 2002 | 11:13 AM
  #41
gigantor's Avatar
Price + features + drivability = DFI Gen 7
Old Dec 13, 2002 | 09:20 PM
  #42
Project_SOHC_EX's Avatar
Dude e-mail if you think there are no tuners. Jeffrey Atwood is CT's best kept secret check out the numbers and clean dyno run of my boy's B16a-T running an Si Greddy kit on 18 psi of boost. You can achieve your goal easily running maybe 14-15psi of boost. Go with Hondata that's what we use on all of our turbocharged cars. Jeff is simply put a ******* scientist and he knows his **** in and out side to side anyway you wanna call it. He is a mechanical engineer from Boston University of Boston college and he now works for T.I. Automotive testing and designing fuel systems. He knows Hondata just as good as the best. After the results off of my boy's JDM B16a we called and Hondata to notify Doug(also the man) of our results. Reason being we were arguing with one of the guys of Pruven Peformance about desired a/f ratios. He thought we were running it too lean and he said it would blow. Well Jeff was a 100% correct. Greg Fodor(my other buddy and owner of the car) called Doug at Hondata and notified him of our a/f ratio which I believe was about 12.3 or so. Something like that. He said that was perfect. We are now in the process of getting CT on the map. If you need the Hondata we can order for you. You can reach me at (203) 526-0961 or e-mail me @ projectsohcex@aol.com. My name is Abdul.But for now just enjoy the dyno and setup my boy ran on his car!
Old Dec 13, 2002 | 09:25 PM
  #43
Here is my friend's set up he actually wrote this in response to an unbeliever.
the motor was biult. It has balanced crank, polished crank, comp. valve job, stainless steel vales, turbo cams by crower, tit. retainers, dual springs, redline at 10000rpm but have hondata with stage 4 with 1988 pr3 ecu non obd so redline is 9000rpm. However, since I am not making power that high I moved it down to 8700-8500rpm. rc 550 injectors running at 85%, aem fpr at 50psi, warlboro 255lph fuel pump, 18g greddy turbo, greddy bov, tial 40mm wastegate w/1bar spring(14.5lbs), greddy intercooler front mt, greddy oil cooler, 9:1 comp, crower rods, srp pistons w/3.209 bore, str block saver, 2.5" downpipe, 3" thermal exhaust turbo, str fuel rail, aem cam sprocket adj, cams degreed 3 retard on exhaust, 3 retard on intake, combined 6 off at crank, deburred head, blue printed motor, gasket matched, hondata intakemanifold gasket, air fuel ratio,s at 12.3, little cam produced 253hp and 218 torque at 6500. Tuned with wide band o2 sensor by my friend jeff. dyno time was 3 hrs. needed more but ran out of time to use the boost controller.
made 321hp and 231 torque on 14.5 psi. just bought a 18.5 pound spring.
all of this in a 1988 crx, 2050lbs. I am the owner and semi builder in bridgeport, ct.
_______
"Greg, what time do you get off from work? Ahhh 3:21."
Old Dec 13, 2002 | 09:29 PM
  #44
Last but not least the promised Link: Enjoy dude and contact me. Thumbs Up Racing "Putting CT On The Map!!"
https://honda-tech.com/zerothread?id=329252
[Modified by Project_SOHC_EX, 6:30 AM 12/14/2002]
Old Dec 14, 2002 | 02:02 AM
  #45
turbopanda's Avatar
Default Re: Poll: Which Standalone.. (Project_SOHC_EX)
For the money and features, i've been using Link engine management products for the past 3-4 years that i've been playing with turbocharged Honda engines. Easy tuning via keypad (looks a bit like the A'PEXi PowerFC hand controller) or laptop, and its plug-in, and doesn't require endless amoutns of ROM burning and emulators like the hondata does.
I used the TurboLink piggyback for my D16Y8 (which worked in conjunction with my stock ECU) and in my integra, i'm using the plug-in IntegraLink ECU. Its brilliant, many features that you wouldn't find in a Hondata, and at a cheaper price. Link products are made in New Zealand, and are famous in the turbocharged Miata world.. There's a few other users here apart from myself who are running Link ECUs.. Check out their website: http://www.link-electro-usa.com
Old Dec 14, 2002 | 08:23 AM
  #46
metal-x's Avatar
Default Re: Poll: Which Standalone.. (turbopanda)
"http://www.link-electro-usa.com/"
the link don't work
Old Dec 14, 2002 | 09:37 AM
  #47
Jefnes's Avatar
Go with Hondata: You keep the factory ECU, just change the chip...
Call Greg Fodor at Dave's Shell in Bridgeport, CT.
(203) 330-0872
He's a dealer, (not enough sales yet to be 'listed')
Ask for Greg or leave a message for me, Jeff
I tuned his B16A powered CRX to 333 whp, 248 ft/lbs using Hondata and
my Motec PLM.
We don't have a dyno, but I street tuned his car then finished
at the tuning on Pruven's dyno, in 3 hours.
What trim turbo?
What sized injectors?
If you have 46+ trim TO4e and 550cc+ sized injectros, you'll make 300whp,
no problem.
Drop me a note if you have any questions:
Jeffrey_Atwood@hotmail.com
Jeffrey Atwood BSME
Edit: I didn't read the entire post before posting...
[Modified by Jefnes, 6:41 PM 12/14/2002]
Old Dec 14, 2002 | 11:05 AM
  #48
turbopanda's Avatar
Default Re: Poll: Which Standalone.. (metal-x)
the link don't work
yes it does...
i think there's something wrong with your net connection..
Old Dec 14, 2002 | 09:18 PM
  #49
25 Year Member
Default Re: Poll: Which Standalone.. (Jefnes)
thanks for all the replies guys---
glad to see there is some CT shops/tuners around. I never heard of them... you guys need to talk more
my setup/build is not complete yet... im hoping for late winter/early spring for the complete car built and tuned (my motor isn't even in the car yet... but i have parts up the wazzooo)
I will get in contact with you folks as times gets nearer....
as for pruven- they know subarus- not hondas... and thats why i wouldn't go to them.
for CT guys
Old Dec 14, 2002 | 09:19 PM
  #50
25 Year Member
ohh- also,
I notice that airjockie posted that he took pics...
I met up with him at a meet this summer... good guy... do you guys know him personally?
