PLX M300 problem
Old Oct 19, 2008 | 06:22 AM
dpetro1's Avatar
Default PLX M300 problem
hey guys, looking for some help on my m300 wideband. not the typical my sensor is bad question. ive had this for about 2 years on my old setup. worked flawlessly. swapped it over to my new car and im getting some funky readings.
power at a25
ground - ive tried a24, a23 and a bolt under the dash with similar results.
brand new bosch sensor (even though i think the old one was fine)
it powers up just fine and reads 14.68 until the sensor warms up (normal)
then it will read and update quickly like normal but then it hangs on rich or air for minutes at a time this is during cruising when i know the afr is not 20:1 or 10:1. does the same thing at idle sometimes, if i blip the throttle it will start reading correctly again.
long story short, it sounds like a wiring issue but i dunno how hard power and ground can really be, is the unit malfunctioning? ive emailed plx with no response
Old Oct 19, 2008 | 08:42 AM
ralph11sec's Avatar
Default Re: PLX M300 problem (dpetro1)
unit problem. 2 years wideband lifetime is pretty long already
Old Oct 19, 2008 | 09:05 AM
dpetro1's Avatar
Default Re: PLX M300 problem (ralph11sec)
yeah i expect the sensor to go out but not the actual controller box.
anyone else care to chime in??
Old Oct 19, 2008 | 09:33 AM
GSROWNSU's Avatar
that sounds so strange how can it be a unit problem? After a couple years the unit just goes bad? I know the sensors can go bad but the unit sees no abuse. In for answers..bump
Old Oct 19, 2008 | 03:40 PM
miguel329's Avatar
yea i couldnt see why the unit would go bad..
Old Oct 19, 2008 | 04:04 PM
dpetro1's Avatar
Default Re: (miguel329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miguel329 &raquo;</TD></TR><TR><TD CLASS="quote">yea i couldnt see why the unit would go bad..</TD></TR></TABLE>
any thoughts on the funky readings im getting?
Old Oct 20, 2008 | 10:17 AM
drSquish's Avatar
well is it man made and electronic?
Old Oct 20, 2008 | 05:17 PM
whiteef8's Avatar
Default Re: (drSquish)
any calibration factor? In for answers/experience as I just bought one and my build is almost done
Old Oct 20, 2008 | 05:27 PM
ralph11sec's Avatar
Default Re: (whiteef8)
how about the wideband and narrow band output. do they work?
before my plx display hangs, but i can continue datalogging through wideband output (white wire)
Old Oct 20, 2008 | 09:29 PM
dpetro1's Avatar
Default Re: (ralph11sec)
they seem to read the same as the display. if the display hangs on AIR the wideband output will stick on 17.86 in hondata (havent corrected the offset since the unit is reading funky)
Old Oct 22, 2008 | 11:23 AM
dpetro1's Avatar
Default Re: (dpetro1)
bump for more ideas
Old Nov 8, 2008 | 03:37 PM
megomaniac's Avatar
I've read that the ground location is critical, power from a switched source in fuse box and grounded near ecu, thats just what i read, haven't done it ...yet
Old Jan 3, 2009 | 11:04 AM
kulo's Avatar
where can u get a replacement plx m300 wideband sensor?
Old Jan 3, 2009 | 04:46 PM
DRAGLS's Avatar
Why don't you wire it directly to the battery and see how it behaves..
Old Jan 3, 2009 | 05:03 PM
ONE*SICK*FERIO's Avatar
i dont have the gray wire conected and works fine plx m300 tho.
Old Jan 5, 2009 | 05:45 AM
dpetro1's Avatar
i thought this thing was dead. glad to see some people are still interested. my m300 is on the way to plx right now for inspection. ill post up the results ASAP. i have a new m300 that is working just fine now
either online from a plx dealer or at any auto parts store, its just a bosch sensor. 1.8t jettas use the same one. ask for bosch part# 17014
garnet
Jun 28, 2014 05:20 PM
europa
Honda S2000
Apr 25, 2014 10:31 AM
dolbo74
Sep 14, 2008 03:35 PM
ebp_dc2
Jul 16, 2007 06:35 PM
mugenhatchie
Jun 16, 2006 09:34 AM
