PLX 300 install question
Old May 29, 2005 | 07:53 PM
DC2-JRSC'd's Avatar
Default PLX 300 install question
Right now im just want to monitor my AFR (no datalogging or uberdata installed) and I used the wideband 02 sensor in place of the stock one so I had to splice the 02 wire on the ecu with the gray wire from the plx, but I get code 41 "Primary oxygen sensor heater". Is that normal?
Old May 29, 2005 | 07:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: PLX 300 install question (DC2-JRSC'd)
yes, because the plx sensor isnt heated
Old May 29, 2005 | 08:05 PM
DC2-JRSC'd's Avatar
Default Re: PLX 300 install question (wantboost)
So i shouldnt worry about it? It doesnt affect anything right? I will install uberdata soon but right now i wanted to get a feel of the AFR's on the stock ECU.
Old May 29, 2005 | 11:07 PM
mtber's Avatar
You need to disable open loop & o2 heater in UD.
Old May 29, 2005 | 11:19 PM
DC2-JRSC'd's Avatar
Default Re: PLX 300 install question (mtber)
i understand that but i just wanted to know if i can run as is for now, untill i install uberdata. will code 41 affect anything?
myEKsedan
Engine Management and Tuning
Apr 3, 2013 05:05 AM
julianbc2
Jul 19, 2010 08:15 AM
HoUTX98GSR
May 9, 2005 05:05 PM
