Plug Gaps
Old Jun 5, 2002 | 12:39 PM
2K1NBGSR's Avatar
Default Plug Gaps
-I'm finishing up my install, and all that's left is put the plugs, wires, and fill it up with oil. I have NGK 1283 (BKR7E-11) spark plugs. What should i gap them at?
-Also what kind of oil did you all use for your break in, and after your break in. Where i work, i have access to all Mobil 1 products, but i heard to use a Non-detergent oil for break in, and to use a heavier oil after and a non-synthetic oil, since synthetic is so thin? What weight oil should i use?
Old Jun 5, 2002 | 12:43 PM
b18bturbo's Avatar
Default Re: Plug Gaps (2K1NBGSR)
use .030 gap on the plugs
Run 10w30 std oil i use just plain castrol gtx 10w30. break it for about 3-4 oil changes and then replace with synthetic.
[Modified by b18bturbo, 3:52 PM 6/5/2002]
Old Jun 5, 2002 | 12:48 PM
H23ludedude's Avatar
Default Re: Plug Gaps (b18bturbo)
You can gap them a little higher if you have an aftermarket ignition. Mine are gapped at .035 with MSD SCI and blaster SS.
Old Jun 5, 2002 | 12:52 PM
b18bturbo's Avatar
Default Re: Plug Gaps (H23ludedude)
very true if you got igntion you can gap them higher.
Old Jun 5, 2002 | 12:58 PM
Anubyss's Avatar
The break in period...do you go to regular oil no matter what? I thought it was only if you changed the pistons. So if I go turbo, I should changed from synthetic to regular oil for the break in period? Thanks.
Old Jun 5, 2002 | 01:56 PM
PrecisionH23a's Avatar
so...... wanna steal some mobile 1 tri-synth 10-30 for us all??? hehehe.
Old Jun 5, 2002 | 02:25 PM
PM-Performance's Avatar
Default Re: Plug Gaps (GudeH23a)
i just got a set of them too . im running nitrous though
i was gonna run .30, but i have msd dig 6+. should i go .035 too?
how can you tell if its gapped right for your application?
sorry if that sounds stupid, but i have no clue.
svhiker
Aug 4, 2017 03:19 PM
gooblinn258
May 12, 2014 10:54 AM
p3t3rxp4n
Jul 23, 2006 02:04 PM
d8168055
Nov 23, 2002 07:06 PM
ithrowpoop
Oct 5, 2001 11:27 AM
