Please judge/feedback on current build for son
most parts already purchased
1991 ef sedan dx
d16z6
comp 59500 supertech springs stock retainers, head completely rebuilt/surfaced/valve job
vitara pistons speedfactory no notch, acl bearings , block .5mm over and surfaced
skunk 2 intake mani, tb, 1000 cc inj
arp studs, je proseal
p28 ecu with s300/ obd1 swap stuff / mpfi conversion
plm top mount / borg warner s256 .48 housing
mishi intercooler , built own 2 1/2 piping
spec clutch / factory trans for now
mostly do v8 stuff, first d16 build. Hope to get some cnc work done get flow on head up as well.
1991 ef sedan dx
d16z6
>BorgWarner S256 .48 A/R
Very interesting turbo choice, not to say it won't perform well down low. BW has always had some of the best journal bearing turbos IMO, even if that S256 is an extremely antiquated design at this point.
Parts list looks good to me. Fuel pump?
The car will be fun, they are light and dont need much power. Next step save for a diff!
fuel pump is 535 i got in tank, wired and on 40 amp relay. -6 crimped teflon stainless braided lines all the way up ( I work in hydraulics) hunter tuned rail
thanks on the turbo choice. any guesses when it will light ???? im thinking 4-4500 ish ???? really hoping to get head CNC work .. get flow up , im thinking this is the best way to get good power on moderate boost. 20-25 daily
Make me some lines for my surge tank. Pls thanks
From: That's the wrong tone... I'm Skunk2 certified.
I had a .48 hot side on a t3/t04e back in the day on a stock b18a. It was very, very fun. Seemed really well-sized for the motor, had full boost by like 2600ish, IIRC. Pulled great all the way to stock redline.
Yeah that sounds ideal for just a fun little street car, or even for small autocross courses.
D16Z6-Turbo
Jan 6, 2018 10:32 PM
1qucksol
Apr 29, 2009 06:13 PM
MikeLuder
19
Feb 12, 2009 11:18 AM
