please help
Old Feb 8, 2005 | 11:11 PM
Redhatchsi1.6's Avatar
Default please help
i posted this on tamparacing and got no help so I think i'm going to give it a shot here...please read below:
I was wondering what would cause my car not to start???, for about a week when I went to start my car it would sputter and then fire, well about three days ago after took my car for a test run i let it idle down and then shut it off, when i went to start it up again nothing not even a starter "click"...so i check to see if maybe i blew a fuse nothing, then I looked at the battery to see if it had power that's fine, is there something that i'm missing please help a fellow honda boy out....thanks
here is my setup:
95 eg hatch(5spd)
greddy hybrid kit
dsm 450's
vafc
I don't beat on it at all i try to baby it so i'm like totally lost on this one.
P.S. on a unrealated issue how much would it cost to replace my crankseal i'm leaking oil from oil pan and it looks like its coming from behind the crank pulley..."sorry if i'm not saying it right just a little tired"
thanks in advance for the help.
Old Feb 9, 2005 | 06:50 AM
beepy's Avatar
Default Re: please help (Redhatchsi1.6)
Battery's toast, or the ignition switch.
Try turning the headlights on; no headlights no battery. If that is fine try turning the engine to the "on" position. The CEL and airbag lights should come on as normal. If that's good then it might be the starter motor solenoid, which is on the starter motor in your case.
The rear main seal is a PITA to replace, and it will be costly.
Old Feb 9, 2005 | 06:43 PM
Default Re: please help (beepy)
yeah the car headlights turn on and when i turn the key to the on position everything lights up (cel,airbag,etc,etc) i can even hera the fuel pump prime itself but no crank....o well maybe the starter is bad....around how much is a rear main seal going to cost me to replace(just trying to get a price) thanks
morales_rafael
24
Jun 9, 2012 07:04 AM
SikB
Apr 22, 2009 01:50 PM
skunk2415
Sep 4, 2006 03:30 PM
spidermang
May 17, 2005 06:49 AM
aznsins88
Dec 30, 2004 09:10 PM
