placement of wideband o2 sensor?
Old Dec 5, 2002 | 06:17 PM
keebler65's Avatar
Default placement of wideband o2 sensor?
i purchased the techedge v 1.5 which has a narrow band output that can be fed to the ecu, so that you can eliminate your stock sensor(s) and just use the wideband. my question is, i know a lot of the newer cars have the sensor near the cat but on my b16a its right by the head. my question is can i use this location for the new wideband sensor? will it read accurate in this location? is it too hot here for it where it might shorten the life? if i can use the stock bung it would make life a lot easier.
thanks
Old Dec 6, 2002 | 08:17 AM
keebler65's Avatar
Default Re: placement of wideband o2 sensor? (keebler65)
ttt
Old Dec 11, 2002 | 11:47 AM
spike's Avatar
sorry to bring up an old post but i am also curious.
Old Dec 11, 2002 | 12:02 PM
Adi Radoncic's Avatar
On Fire!
Well on FI cars you would usually put the sensor about 2-3" away from the turbo on the down pipe you your getting a acurate reading, so I don't see why you couldn't put it in your stock location on the B-pipe....
It would be very acurate in that location..
Adi
Old Dec 11, 2002 | 01:46 PM
keebler65's Avatar
Default Re: placement of wideband o2 sensor? (newgsr)
i was just concerned that since the wideband has its own heater and the stock one doesnt that the wideband might overheat. you dont see this as a problem then since it will be so close to the head?
thanks
Old Dec 11, 2002 | 02:58 PM
Farnsrocket's Avatar
I would ask Techedge about it if you can get in touch with someone there.
WhiteOnRice
Jun 22, 2007 01:12 PM
JoshRambo
May 15, 2003 01:09 PM
Jebus
Mar 21, 2003 02:43 PM
Blown90hatcH
Jan 7, 2003 02:37 PM
