pistons questions
hello, i am in the process of turbocharging a 92 ls b18 motor. I am planning on doing everything but sleeve the block, the problem is that i have been told that i cant use aluminum or steel pistons in the b18 cast iron block without sleeving it. Is that true. If not what kind of pistons do you guys recommend. THANKS ALOT
