pistons for h22 build
im in the process of starting to buy parts to build my h22... currently am running 8 psi on the stock motor in my 01 prelude... but i want to get a lot more out of it than that... my ? is which pistons do you guys recommend for say a 15 psi daily driver and over 20 psi for the track... and also which pistons will take the most abuse and still last for a long time?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">We use Arias pistons exclusively. Consistent on the piston clearances and we use them in plenty of high boost race engines.</TD></TR></TABLE>
Does the Arias pistons still have "Piston Slap?" I remember on my old motor it slapped alot on my h22 back in 2002. I think the machine shop may have just ran piston to wall a little too loose.
What piston to wall clearance do you run?
no piston slap at all. we use about 5-10 Arias pistons per month and all have been great.
Clearances are a factor as well like with any piston brand. We run the spec required by Arias.
