Piston to Wall clearance VITARA??
Hello guys, I'm looking to gather some information on clearences for the Vitara build.
Can you guys share the piston to wall clearance you are using.
What about ring gaps and rod / main bearing clearences?
Thanks!!
Thanks!!
My vitaras was bored to 0.08mm piston to cylinder clearance. Rings that came with pistons was out of oem spec but it works fine.. 10K miles now on engine. No piston slap.
Thanks for the feedback guys.
I assume you are using factory ring gap alignment as well?
Please keep the reponses coming! I like to hear about other setups as well.
Ring gaps are different per app. If you plan to boost you run more then a a/m build. What hp do you plan to try and make?
blackeg
Feb 15, 2014 05:03 AM
4EN[sic]
Aug 9, 2007 04:19 AM
