Piston to wall clearance
Old Jan 24, 2007 | 07:36 PM
plonger's Avatar
Default Piston to wall clearance
What is the best clearance to run on oem piston to cylinder wall ? Oem clearance ? Or a little bit more loose ?
The block is a gsr 81.5mm and it won't have much more than 300 whp
Old Jan 24, 2007 | 07:43 PM
Muckman's Avatar
Moderator in Chief
Default Re: Piston to wall clearance (plonger)
oem piston = oem clearance.
Old Jan 24, 2007 | 08:50 PM
turbodegsi's Avatar
well the piston company should have a sheet on where you're supposed to run them at..(if name brand piston)
but if you google endyne they have good info on building tips
Old Jan 24, 2007 | 10:14 PM
xxxmikenicexxx's Avatar
Default Re: Piston to wall clearance (turbodegsi)
Like said, it all depends on the pistons you are running...and even then, depending on preference, the boost being run can dicticate looser/tighter tolerances.
Old Jan 25, 2007 | 03:46 AM
plonger's Avatar
Default Re: Piston to wall clearance (xxxmikenicexxx)
it's nippon piston
Old Jan 25, 2007 | 12:24 PM
blackeg's Avatar
run them at the piston manufacturers specs. if you are running real high boost or a high silicon content piston then the specs might vary a tiny bit
Blake St.romain
Aug 26, 2018 08:34 PM
Drew17th
Oct 28, 2006 06:02 AM
W C L
Oct 17, 2005 01:51 PM
redDAinteg
Apr 26, 2005 09:48 AM
Boostless97Lude
Apr 28, 2003 04:30 PM
