Piston and rod upgrades
hey everyone talks about sleeving there blocks to get crazy power, but what if u just wanted to upgrade pistons and rod's?
have ppl got good results from just this?
thanks
thanks
You can make good power with just pistons and rods, jinx has proven this with i believe 450+whp. A sleeved block just adds that extra sense of security that you wont crack a sleeve under HIGH boost pressures. Personally, id rather fork out the extra $700ish to have it done right the first time and know that i have a bullet proof block. But keep in mind, tuning is everything. You can have a fully built motor, but if it isnt tuned properly you can blow your motor, melt your pistons, etc. If you keep your stock sleeves and push 12+psi, make sure you have a top notch tuner.
sleeving isnt necessarily doing it right, i mean for my car, forged pistons and rods with proper engine managemnt will do, as will most likely for you guys, its just that sleeved people usually end up running really high boost from my observations,
this quote should be kept at the top of EVERY forced induction forum of all kinds of cars, some poeple think forged internals make you invisible to detnation , bad AF ratios etc, like dude said above, tuning is the key, if i were you, i would turbo first, then upgrade the pistons so you have somehting to look forward to, i run 9 psi on my 2.0 8v sohc, and when i get sds stand alone, i will be seeing 17 psi
But keep in mind, tuning is everything. .
yea i would love to get sleeves but its either sleeves or a standalone and i would rather a standalone
i will only b pushing around 12-14psi daily driven
what would b the best piston, rod combination?
and what compression would be best?
2.2 teg
Dec 20, 2006 04:09 PM
