Pipe size.
Old Apr 16, 2002 | 03:33 AM
KooK's Avatar
Mustang Sally
Default Pipe size.
If I get a 3 inch exhaust all the way around (headers, cat, catback) will I be able to keep it when I bore out my engine and add a JRSC or will the piping have to be larger for better flow? Thanks!
Old Apr 16, 2002 | 03:37 AM
BlueSi2k's Avatar
Default Re: Pipe size. (Tapeworm)
You definately wont need to go bigger than 3" with JRSC but i would wait until you have it to do the exhaust. If you're sitll n/a you're gonna lose some low end torque with the 3". HTH
Old Apr 16, 2002 | 05:31 AM
BlueShadow's Avatar
Default Re: Pipe size. (BlueSi2k)
bigger than 3 inches on a JRSC GSR?!? how do you figure that? a lot of people that are boostin high PSI/HP numbers are doing fine with 3" exhausts...
EDIT: and to answer the original question, 3" might be a little too big for the header. I hear Kamakaze headers are just the right diameter for Supers.
[Modified by BlueShadow, 2:32 PM 4/16/2002]
Old Apr 16, 2002 | 09:53 AM
ninesecrx's Avatar
3 thats fine..........
Old Apr 16, 2002 | 09:57 AM
Liltrix's Avatar
Default Re: Pipe size. (BlueShadow)
Blue shadow did U read the previous post properly before posting?
Old Apr 16, 2002 | 11:55 AM
Xerxes's Avatar
New User
Default Re: Pipe size. (Liltrix)
lol when i first read it i thought he said to go bigger as well! but then i re-read it
Old Apr 16, 2002 | 12:49 PM
tonydatyga's Avatar
How much are you trying to bore it out... 5 liters?? 3" will be fine for anything under that assuming jrsc boost somewhere around 8psi. Btw, 3" piping is raunchy w/o FI... consider waiting and doing it all at the same time.
jrscgsrboy1985
Oct 16, 2006 03:46 PM
2K Teggy
May 11, 2006 09:08 AM
gubo22
Sep 7, 2003 12:46 PM
stickshift
Aug 15, 2003 04:08 PM
MachAF
Apr 12, 2003 06:02 PM
