pics of my project
Old Nov 6, 2002 | 08:36 PM
delux247's Avatar
Default pics of my project
ok i over boosted im motor in may and ever since i have just gone overboard
heres my list of mods so far (if anyone cares)
b16a2 bored to 83mm =sold
b18c1 bored to 83mm current project motor being sleeved right now at golden eagle
JE 10:1 pistons, crower rods, jun lightweight flywheel, act 6 puck clutch, portflow port and polish, jun springs and retainers, ctr cams, spoon cam gears,JG Edlebrock intake manifold, t3t04e garrett turbo, soon to be the owner of the beautiful full race manifold,xs intercooler, rc 720cc injectors,
atl fuel cell paxton fuel pump yadda yadda yadda
the car was red, then white, now ive painted it ford dark shadow grey, it was the first thing i have ever painted and i think i did a pritty damn good job i did all the body work my self and sprayed it my self
im building the car for the togue and freeway racing so suspension is just as important then the motor
i still have a ways to go but i hope to have it done by feb so ill keep everyone posted
Old Nov 6, 2002 | 08:40 PM
Suprdave's Avatar
Default Re: pics of my project (egcivicturbo)
Lookin' good so far...
Suprdave
Old Nov 6, 2002 | 08:47 PM
RyanAutry's Avatar
b18c1 bored to 83mm
sleeved golden eagle
JE 10:1 pistons
crower rods
act 6 puck clutch
portflow p&p
ctr cams
spoon cam gears
full race manifold
xs intercooler
rc 720cc injectors,
Sounds like a 400+ Wheel HP Project to me...
Nice Job...
Old Nov 6, 2002 | 08:54 PM
inspyral's Avatar
Default Re: pics of my project (RyanAutry)
I like the stew pot full of coolant
The rest is nice too.
Old Nov 6, 2002 | 09:01 PM
Adi Radoncic's Avatar
On Fire!
Holy ****!!! Now thats what you call a FRONT MOUNT!!!
What size is that thing in inches??
Adi...
[Modified by newgsr, 12:01 AM 11/7/2002]
Old Nov 6, 2002 | 09:20 PM
Chrome Pipes's Avatar
How much psi was "over boosted"?
Old Nov 6, 2002 | 09:50 PM
project dc2's Avatar
Default Re: pics of my project (Chrome Pipes)
whats your painting like ? procedures ? first time painting anything ? list some steps and info. as well as personal skill etcc .. how much it cost yada yada .. very very itnerested !
Old Nov 6, 2002 | 10:24 PM
D-SPEED's Avatar
Default Re: pics of my project (project dc2)
lookin good
Old Nov 7, 2002 | 12:21 PM
lazyvietboi's Avatar
did you do a 96+ civic front on it?
Old Nov 7, 2002 | 02:38 PM
inspyral's Avatar
Default Re: pics of my project (lazyvietboi)
That looks like an EG front end. The 96+ radiator support is different.
Old Nov 7, 2002 | 02:46 PM
Prod's Avatar
Just want to say, sick choice on the color. Throw some black wheels on it and that thing is going to look great.
TurboDANDEE's Avatar
Default Re: pics of my project (inspyral)
does the "XS Engineering" logo come standard on those intercoolers or did u painted it on?
Old Nov 7, 2002 | 03:23 PM
technine's Avatar
I know the procedure, but is it as hard as it sounds like? What kind of sander did you use and what kind of paint did you use also? I am going to use my sanding wheel on my drill and go over the car with maybe 400 something grit to get a nice surface, clean it up and spray it with maybe 3 coats of color and then 2 clears (maybe 1, I'm lazy).
Hope it's not as hard as I think it's gonna be (time wise at least).
Old Nov 7, 2002 | 03:48 PM
madmatt's Avatar
Default Re: pics of my project (technine)
that is a sick project man. that engine will straight own. What kind of engine management are u goin to use? Keep it up and let us know as it comes along.
Old Nov 7, 2002 | 04:47 PM
delux247's Avatar
Default Re: pics of my project (madmatt)
wow i didnt think i would have such positive feedback,
well to start awnsering questions
the body work alone took me 6 months both the door panels are new
i have five coats of base coat and four coats clear i used the best ppg made
when it came to sanding i went over the whole car with 320 then wet sanded with 400 then finally wet sand with 600 the paint job is flawless it took me 12 hours to paint it and it was definatly a learning experience but the number one thing is be patient if your not youll screw it up and the paint alone cost 600.00 not to mention all the man hours...
ill be using the apex'i power fc for now but i dont know what the final engine managment will be ...
suspension will be a huge upgrade consisting of
endless front brake system i baught from koi (great guy )
competition engineering cromoly front arms, type r steering rack, king motor sports upper controll arms
in the rear
rear disk conversion with type r calipers brembo rotors endless pads
more pics
before the paint job
before clear coat
during clear coating
endless calipers
fuel cell and no back seat it will be replaced with aluminum
the roof my favorite
ill keep you all posted
Old Nov 7, 2002 | 04:50 PM
stick's Avatar
u should really consider using stock GSR camshafts instead of CTR cams.
unless that is a type-o
keep us updated on the continued project.
Old Nov 7, 2002 | 04:54 PM
Projekt20's Avatar
I have the same IC....mind posting how you mounted it, mounting points and such? Thanks.
-Trung
Old Nov 9, 2002 | 10:13 PM
delux247's Avatar
Default Re: pics of my project (Projekt20)
bump
Old Nov 9, 2002 | 10:50 PM
B20LS-T's Avatar
New User
That is a great job on the paint, ive been practicing for a while and cannot get away from this damn orange peel. What type of gun did you use? gravity feed or siphon feed? what type of compressor and the ratings in cfm? thanks for your help.
Old Nov 10, 2002 | 05:30 PM
Danger's Avatar
Default Re: pics of my project (B20LS-T)
nice paint job . good luck with your car . i have a similar build up that im doing with my b18c5 . post the updates .
Old Nov 10, 2002 | 05:53 PM
jl2teg's Avatar
Default Re: pics of my project (jonny5)
sweet
Old Nov 10, 2002 | 07:40 PM
DUCK COMMANDER's Avatar
Default Re: pics of my project (jl2teg)
looks top notch from here..nice front mount
Old Nov 10, 2002 | 07:49 PM
V-SPEC 1's Avatar
Default Re: pics of my project (JSutterEH2)
Not bad at all.
Old Nov 10, 2002 | 07:57 PM
delux247's Avatar
Default Re: pics of my project (boostedb20vtec)
thanks a lot guys i should have more pics of the aluminum rear seat cover i worked on this weekend
i cut out where the rear seat once was and i have paned it all out i think it looks super sweet
Old Nov 11, 2002 | 02:46 AM
ImportHatch's Avatar
damn you really did go all out....
Yager-
