pics of mounted fuel pumps
Old May 26, 2006 | 04:37 PM
redboost10's Avatar
Default pics of mounted fuel pumps
i have a weldon 2035 fuel pump, just wondering if anyone can share some pics of their fuel pumps mounted under the rear of the car. thank you.
Old May 26, 2006 | 09:46 PM
redboost10's Avatar
Default Re: pics of mounted fuel pumps (tgh99si)
anyone have pics of something mounted. just concerned about the weight of the pump.
Old May 27, 2006 | 01:02 PM
redboost10's Avatar
bump again
Old May 27, 2006 | 01:46 PM
80884's Avatar
Here is something. It's not done yet and doesn't run yet but this is how I'm doing it. I will also provide you with a link to some other pump setups at no charge
https://honda-tech.com/zerothread?id=1564100
Old May 27, 2006 | 02:02 PM
redboost10's Avatar
Default Re: pics of mounted fuel pumps (80884)
thank you for the pics, i see the aeromotive has four pre-drilled holes on the body of it. this is similar to what im using, anyone with pics of a weldone mounted?
Old May 28, 2006 | 10:52 AM
Turbocivic94's Avatar
do search under fuel pump and u will pics of turbo-charged setup or pm him
Old May 28, 2006 | 11:33 AM
HYBRID_H@TCH's Avatar
Default Re: pics of mounted fuel pumps (Turbocivic94)
here is mine..if pic doesnt work refresh page..
Old May 28, 2006 | 11:36 AM
spoolinyo's Avatar
looking good
Old May 28, 2006 | 12:26 PM
Default Re: pics of mounted fuel pumps (HYBRID_H@TCH)
bling bling
Old May 28, 2006 | 01:00 PM
redboost10's Avatar
awesome, thank you hybrid hatch
Old May 28, 2006 | 01:27 PM
NP..glad I could help..and yes the tank is painted the same color as the car..
BTW mine is a 2025..with a T-bolt flange clamp holding it inplace.
Old May 28, 2006 | 02:12 PM
philipwight's Avatar
i know this isnt the rear but here is where i mounted my 2035.
Old May 28, 2006 | 02:28 PM
redboost10's Avatar
if its not too much to ask for hybrid, may i have a close up picture?
also, philip, not bashing you, but is it safe to mount the motor of the pump on the underside of the fuel routes? "upside down"
Old May 28, 2006 | 02:39 PM
i guess we will see if it catches on fire. i didnt know that you couldnt mount it like that.
Old May 28, 2006 | 02:51 PM
Default Re: pics of mounted fuel pumps (philipwight)
best close up I have..these pics are like a year old..
Old May 29, 2006 | 09:13 AM
spoolinyo's Avatar
bump any more pics
Old May 30, 2006 | 02:47 PM
swapit's Avatar
Default Re: (spoolinyo)
heres my pump mounted
Old May 31, 2006 | 05:27 AM
underpressure02's Avatar
do a search for threads created in here under my name and you will see some pics. I built a bracket out of 1/4 plate steel it is not going anywhere.
Old May 31, 2006 | 07:36 AM
b18sihatch's Avatar
good pics nice setup
Old Jun 4, 2006 | 08:07 PM
redboost10's Avatar
how does this look? i will use a 1/2 to 12an straight adapter fitting, then a 30 degree 12an hose end, then on the filter side, i will use a 90 degree 12an hose end
Old Jun 4, 2006 | 08:45 PM
redboost10's Avatar
Default Re: (tgh99si)
i mainly wanted to make sure that its ok to use a 90 degree corner on the filter and a 30 degree hose end right out of the sump.
Old Jun 5, 2006 | 08:31 AM
redboost10's Avatar
bump, any comments?
Old Jun 5, 2006 | 10:28 PM
redboost10's Avatar
hopefully it works
underpressure02
Apr 23, 2007 06:21 AM
trecool44
Sep 28, 2005 05:48 PM
1.8
Dec 20, 2004 12:01 PM
ninesecrx
Oct 24, 2003 12:25 AM
JDMsuperWHORE
Feb 10, 2003 07:24 PM
