Pics of DSM injector install...
Old Aug 15, 2002 | 07:37 PM
legendboy's Avatar
Default Pics of DSM injector install...
Took about 2 hours, car idles better than before, likes -25% at idle and i've set it to -40% across the board. I want to make sure everything works good before the turbo goes in.
Old Aug 15, 2002 | 07:51 PM
KoRE's Avatar
Default Re: Pics of DSM injector install... (legendboy)
awesome good job.... my resistors are just hangin maybe i'll zip tie them too
Old Aug 15, 2002 | 07:53 PM
*Boostwerks*'s Avatar
don't the resistors get really hot?
I know that some of my RC car resistors got hot enough to burn paper (THESE ARE NOT ON MY CRX....my RC car)!
Hope it doesn't melt the plastic
[Modified by Bryson, 10:19 PM 8/15/2002]
Old Aug 15, 2002 | 08:15 PM
legendboy's Avatar
Default Re: Pics of DSM injector install... (Bryson)
I think that u need bigger resistors so it disapates the heat a little better, they should not get THAT hot I think.
Old Aug 15, 2002 | 08:18 PM
I never meant that I put the RC car resistors on my CRX....Just that they got really hot with the RC car....
editing ^
[Modified by Bryson, 10:18 PM 8/15/2002]
Old Aug 15, 2002 | 08:22 PM
legendboy's Avatar
RC's
Old Aug 15, 2002 | 09:08 PM
Smashback's Avatar
Yeah they get hot as ****, that's why the Honda ones are enclosed in an aluminum heatsink.
Old Aug 15, 2002 | 09:12 PM
this is getting confusing as ****....
Your thinking the RC "car's" right?....that's what I mean
I do NOT mean RC injectors.....
Old Aug 15, 2002 | 10:56 PM
Gfunk176's Avatar
haha...rc cars...i've spent almost as much into that little sheit as i have into my turbo
Old Aug 15, 2002 | 11:01 PM
Default Re: Pics of DSM injector install... (Gfunk176)
Yeah I have put 600 into my tamyia Monster truck....
The only thing left from the kit in the thing are the Gear Boxes.....
If anyone wants pics I'll go get some.....(it's pretty ******* bad ***)
Old Aug 15, 2002 | 11:18 PM
Gfunk176's Avatar
i would show you pics of my hpi but i don't know how to post pics...i'm kinda a ht noob.
Old Aug 16, 2002 | 12:30 AM
T-sohctec's Avatar
Nice install. Is that a D-series intake mani?
Anyway I just got my DSM's in the mail today and realized they do not connect to my injector plugs. Is it because my injectors are OBDII ?
What gives?
Old Aug 16, 2002 | 02:57 AM
RGAZ's Avatar
New User
Default Re: Pics of DSM injector install... (T-sohctec)
What gives?
The clips won't work, you need OBD0 clips from 88-91 CRX and grap the resistor pack while you are there.
Randy
Old Aug 16, 2002 | 06:31 AM
legendboy's Avatar
Default Re: Pics of DSM injector install... (RGAZ)
My car is OBD1 and all I did was dremel off the nib on the inside of the injector connector, my stock honda clip fits perfectly now. But OBD2 I think is different tho...
EDIT: haha ya, i thought u were talking bout rc cars!
[Modified by legendboy, 8:32 AM 8/16/2002]
Old Aug 16, 2002 | 06:41 AM
CovertFI's Avatar
where did you get thoes resistors from. they are really heavy duty?
Old Aug 16, 2002 | 07:00 AM
cock head's Avatar
Default Re: Pics of DSM injector install... (CovertFI)
what size resistors did you guys use, I went to radio shack and the biggest ones they have 1/2 watt and 10 oms, my injectors are comming in today so I really need to know thanks.
[Modified by therumblingteg, 4:02 PM 8/16/2002]
Old Aug 16, 2002 | 07:18 AM
legendboy's Avatar
Default Re: Pics of DSM injector install... (therumblingteg)
I am using 10watt 10 ohm......I think u should use bigger 10 watt.
Old Aug 16, 2002 | 09:11 AM
Sonny's Avatar
Ghetto fabulous!
Sonny
Old Aug 19, 2002 | 12:17 PM
bryan305's Avatar
Default Re: Pics of DSM injector install... (Sonny)
Is it good to have your throttle cable rubbing on the pcv hose like that?
Old Aug 19, 2002 | 12:26 PM
ricodemus's Avatar
Default Re: Pics of DSM injector install... (bryan305)
I have a first gen b16a in my 90 hatch. Do I still need the resistor box to use the dsm injectors? The first gen runs peak and hold, right? I know they source the resistor boxes from my stock motor, so I'm kinda confused.
Old Aug 19, 2002 | 01:23 PM
Cramerox's Avatar
hey legendboy what kinda car you have? is that obd0? i need to get some new clips for my dsm's anyone know cheap place to get them?
Old Aug 19, 2002 | 01:26 PM
legendboy's Avatar
Default Re: Pics of DSM injector install... (Cramerox)
94 Integra. 0bd1 of course, just dremel the nib on the inside of the injector clip and the honda clip will go right on just like stock.
Help me here! [URL][https://honda-tech.com/zerothread?id=257313/URL]
Old Aug 19, 2002 | 01:27 PM
legendboy's Avatar
Help me here! https://honda-tech.com/zerothread?id=257313
Old Aug 19, 2002 | 03:59 PM
Cramerox's Avatar
but i have obd2 98 intagra
Old Sep 5, 2002 | 10:38 PM
TurbothisLS's Avatar
anyone want to show step by step the injector install?
does anyone know if the injectors are longer than stock LS?
I need to know if they will bolt right in.
I also got the injectors with clips on them from the talon. Should i just solder the new clips to the old wires?
