People help make list of stuff needed for Turbo
Old Jun 25, 2002 | 01:06 AM
boostin GSR's Avatar
Default People help make list of stuff needed for Turbo
-drag 3 turbo kit
-j&s safeguard
-- anything else?
how about the steel braided oil return lines?
Old Jun 25, 2002 | 01:24 AM
mike's Avatar
H-T Order of Merit
Default Re: People help make list of stuff needed for Turbo (BoostinGSR)
I would do something else for the oil return than what drag gives you. I got some earl's fittings and steel braided line from summit.
http://imglib.************/index.cgi?cmd=view&id=4470
I forget what exactly comes with the drag kit but you will probably want some decent gauges such as boost, egt, etc. If you get the dual monitor with your J&S you won't need a A/F gauge. You will also need a stronger clutch if you haven't already installed one. And colder spark plugs.
Old Jun 25, 2002 | 03:38 PM
Default Re: People help make list of stuff needed for Turbo (mike)
-ok, i already have my new clutch and flywheel installed
-why colder plugs? are they a must? i just want to get things running with the turbo
-how about the tial w/g and the missing link?
eric
Old Jun 25, 2002 | 04:30 PM
GSRgrrl's Avatar
Tiel W/g and Missing Link a MUST. Upgrade your oil pan too.
Old Jun 25, 2002 | 04:32 PM
ceemarun's Avatar
Default Re: People help make list of stuff needed for Turbo (GSRgrrl)
what are the downsides to just tapping your stock pan?
Old Jun 25, 2002 | 04:39 PM
dustin's Avatar
Default Re: People help make list of stuff needed for Turbo (ceemarun)
You won't be able to brag that you have a neato oil pan. Other than that, none really
Old Jun 25, 2002 | 08:07 PM
accordfreak's Avatar
Default Re: People help make list of stuff needed for Turbo (dustin)
I'm just wondering....what are the advantages of colder plugs?
Old Jun 25, 2002 | 08:31 PM
jdblack1's Avatar
Default Re: People help make list of stuff needed for Turbo (accordfreak)
To help avoid detotnation. Colder plug transfers more heat to the head so it in turns stays colder
Old Jun 25, 2002 | 08:36 PM
Default Re: People help make list of stuff needed for Turbo (jdblack1)
cool thats good to know... people usually go 2 steps colder with turbo correct? what brand? NGK??
Old Jun 25, 2002 | 08:41 PM
jdblack1's Avatar
I'd say start one step colder but check for proper burning after some driving.
Use a good copper plug, NGK works
Old Jun 25, 2002 | 08:57 PM
b18c1-ek's Avatar
needed = basic Drag 3 kit
recommended = clutch, colder spark plugs, cam gears, Missing Link
niceties = Hondata, Tial, 3" downpipe, SS oil return line, 3" exhaust, JG/Edelbrock intake manifold, 550+cc injectors, AEM FPR, boost controller, Quaife
Old Jun 25, 2002 | 10:37 PM
ceemarun's Avatar
Default Re: People help make list of stuff needed for Turbo (b18c1-ek)
needed =
dont you need the missing link?
Old Jun 25, 2002 | 10:51 PM
saso
Guest
Posts: n/a
If you can afford Str intake manifold go for it. Upgraded throttle body. Guages, water temp. oil pressure. Monster Tach. Hmmm...what else....block guard, Injectors maybe 310cc or 370cc. Msd.etc....
Old Jun 26, 2002 | 06:05 AM
speedymon's Avatar
Default Re: People help make list of stuff needed for Turbo (saso)
The drag kit doesn't come with the missing link?
Old Jun 26, 2002 | 07:43 AM
b18tdelsol's Avatar
Default Re: People help make list of stuff needed for Turbo (speedymon)
yeah,..missing link would be cool, my shity check valve's keep falling off when i race..or have a rough launch.. ::i know it's old school, and i need to upgrage::
Old Jun 26, 2002 | 08:22 AM
93LSivic's Avatar
This is a funny post. I would suggest you add the 40 lb. sack of rocks and maybe some corn starch.
Old Jun 26, 2002 | 11:11 AM
ion_four's Avatar
Why a copper plug? I realize it's a better conductor in someways, but I don't believe the NGK V-Powers (best value plugs) are copper...
Old Jun 26, 2002 | 07:54 PM
jdblack1's Avatar
Default Re: People help make list of stuff needed for Turbo (ion_four)
That's what I use
Old Jun 26, 2002 | 07:58 PM
B-Series Sol's Avatar
Stupid Question:
What is a "Missing Link"?
Old Jun 26, 2002 | 08:16 PM
jdblack1's Avatar
Default Re: People help make list of stuff needed for Turbo (B-Series Sol)
MAP sensor bypass valve which keeps the CEL from coming on
Old Jun 26, 2002 | 08:19 PM
SlowB16's Avatar
or you can get the fish tank valves!! 4 bucks
Old Jun 26, 2002 | 09:16 PM
jdblack1's Avatar
Default Re: People help make list of stuff needed for Turbo (SlowB16)
actually cost me $9
Old Jun 26, 2002 | 10:48 PM
can u explain why and how the missing link works? is this necessary or just a trick of the trade?
Old Jun 27, 2002 | 08:00 AM
jdblack1's Avatar
It's used to bleed boost psi away from the map sensor. If the stock map sensor sees more than around 3psi it will get a CEL.
TurboTeG4
Aug 27, 2003 06:09 PM
cvclover
Mar 25, 2003 02:01 AM
B18EG6
Aug 4, 2002 02:32 PM
AllMotorITR
Aug 3, 2002 09:23 PM
