peakboost kit on crx?
Old Sep 28, 2005 | 12:09 PM
crx-treme's Avatar
Default peakboost kit on crx?
any one running a peakboost kit on their crx? found a deal on brand new kit for a civic, hoping to fit it in with some mods. insights welcome
Old Sep 28, 2005 | 12:17 PM
Origin's Avatar
Default Re: peakboost kit on crx? (crx-treme)
look at the peakboost picture post here in the fi forum. its not a crx but a hatch with the manifold on his motor.
Old Sep 28, 2005 | 12:52 PM
ProjectDarkBlack's Avatar
Default Re: peakboost kit on crx? (Origin)
http://img379.imageshack.us/my.php?image=a7dw.jpg
Old Sep 28, 2005 | 12:53 PM
crx-treme's Avatar
i found it thanks. well im guessing thats the only peakboosted ef on here...
Old Sep 28, 2005 | 01:09 PM
Boostfed's Avatar
New User
You must relocate your battery and use a half rad sir
Old Sep 28, 2005 | 01:14 PM
crx-treme's Avatar
Default Re: peakboost kit on crx? (Boostfed.com)
i dont think i have to relocate my battery, i will most likely have to do custom charge pipes any how. but in those pics it loks like he cut the rad support and used hood pins! i dont want to do that. can any one tell me how far out the manifold is from the valve cover, and how far the wg sticks out. thanks guys
Old Sep 28, 2005 | 01:46 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i have to relocate my battery, i will most likely have to do custom charge pipes any how. but in those pics it loks like he cut the rad support and used hood pins! i dont want to do that. can any one tell me how far out the manifold is from the valve cover, and how far the wg sticks out. thanks guys</TD></TR></TABLE>
OK I am a dealer for PeakBoost and when I sold a CRX kit last week, Ken Peak the owner of PeakBoost/Phoenix Turbo advised me of these modifications to make the kit work BUT if you say sooo
Old Sep 28, 2005 | 01:53 PM
crx-treme's Avatar
only reason i say that is cuz ive seen plenty of rexes/hatches with charge pipes routed around the battery. i will not be buying a kit for a crx, so i will need custom charge pipes. if the manifold or turbo some how got in the way of the battery, then ok i will relocate. this post was mainly to see what kind of wastegate /manifold clearance there is since the pic above has the radiator support cut up. thanks for your input. also i am aware of the half sized rad situation.
Old Sep 28, 2005 | 01:56 PM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">only reason i say that is cuz ive seen plenty of rexes/hatches with charge pipes routed around the battery. i will not be buying a kit for a crx, so i will need custom charge pipes. if the manifold or turbo some how got in the way of the battery, then ok i will relocate. this post was mainly to see what kind of wastegate /manifold clearance there is since the pic above has the radiator support cut up. thanks for your input. also i am aware of the half sized rad situation.</TD></TR></TABLE>
pm sent
Terry is correct, to save you a bit of time from making custom charge pipes to clear the battery, it is much easier to relocate the battery to free up room for the civic charge pipe kit. imho.
otherwise, we have installed many manifolds on the 88-91 cr-x and ef chassis' without modification. i am unsure of fitment on the earlier model crx...
thanks
Ken Peak
Old Sep 28, 2005 | 01:57 PM
crx-treme's Avatar
crx-treme (4:55 PM 9/28/2005): hey i was wondering if the peak boost manifold will fot on a b series crx without major modification?
PhoenixTurbo.com (5:53 PM 9/28/2005): hey,
the PeakBoost B-series manifold fits the crx and ef chassis without modification. the only necessity is that a 92-00 civic style radiator must be ran to clear the 38mm wastegate.
let me know if you have any other questions 1-877-23-turbo
thanks
ken
crx-treme (5:55 PM 9/28/2005): thanks my man, i spent all day trying to find out this information! ithank you kind sir
thanks ken!!!!!!!!
Old Sep 28, 2005 | 01:58 PM
crx-treme's Avatar
thank you all
Old Sep 29, 2005 | 02:00 AM
BlueShadow's Avatar
Keep in mind that you have to select your crossmember and radiator carefully. In most cases if you stick a Fluidyne EG radiator in you EF that has say a Full Race traction bar, then the radiator will be too tall. It looks like that guy has his radiator over towards the passenger side more. I have the same radiator in my CRX with Full-Race traction bar and it sits in the support tabs. And from the looks of it You would haveto do something similar to that guys setup to be able to use the peakboost manifold.
Here is a pic of the PWR shorty radiator installed on the Full-Race traction bar's radiator tabs. Compare the radiator outlets and radiator caps on the two pics. See how they are lined up differently with the motor?
-In the Full Race pic the rad outlet is lined up with the VTEC solenoid
-In the imageshack photo it is lined up with the black part of the dizzy
-In the imageshack photo the rad cap is lined up with the valvecover acorn nut
-In the Full-Race pic the rad cap is over to the drivers an inch or two
That is my car in FR's pics BTW
http://www.full-race.com/catal...w.jpg
Old Sep 29, 2005 | 09:27 AM
crx-treme's Avatar
Default Re: peakboost kit on crx? (BlueShadow)
ok so i guess i need a rad that is about a foot wide, thats from the left mounting point to the acorn nut on the valve cover. the pwr is too wide. hmm....
siblues
Welding / Fabrication
11
Nov 1, 2006 02:26 PM
drjondurst
13
Nov 14, 2005 07:04 PM
streetinformer
Aug 2, 2005 08:39 AM
92TEGsrSC
Dec 23, 2004 01:21 PM
rexinfection
Oct 23, 2002 09:19 PM
