Peak and Hold or Saturated injectors?
whats the difference and which ones should i get with a turbo'd gsr. right now i have a vafc but i will probably get the aem ems soon.
Hope this helps,
Your OBD1 ecu (EMS or OEM) will expect saturated injectors. Generally, you can only get saturated up to 440cc/min (custom injectors aside). Above that (550+) you'll need to use an injector resistor box in conjuction with peak & hold injectors.
http://www.hondata.com/techinjectorwiring.html
