Which Peak and Hold injectors?
Old Dec 18, 2008 | 06:09 PM
shawn69's Avatar
Default Which Peak and Hold injectors?
hey, i'm looking for new injectors. They need to be peak and hold (low resistance). For anywhere between 300-475hp. On a B series.
I've hear that the RC PL4-0750H lock up under high pressure?
http://www.rceng.com/---PL4-0750H-Ho...top-P56C5.aspx
They say max 100 PSIG.
I'm thinking of either 650cc or 750cc. or should i just go with Precision 1000cc/min?
How much does it really effect your idle? I'm planning on driving this car everyday.
Shawn
Old Dec 18, 2008 | 07:08 PM
SD_Lurker's Avatar
HT White Ops
not to sure why you NEED peak and hold but in any event you should check out tony1's new bosch injectors.
Old Dec 18, 2008 | 07:56 PM
TheShodan's Avatar
Moderator
OEM resistor boxes are no big deals to utilize. The parts b/w Bosch/Rochester Lucas/Siemen Deka are very very similar. So be it one type or another, your management would be more responsible for your idle issues than anything else. If your hp goals are reasonable, you don't have to go to 1000ccs. After 1200cc/min or 120lb/hr, you'll have idle issues anyway.
barraea
Engine Management and Tuning
Jun 15, 2016 06:45 AM
Charlie Moua
Jul 25, 2013 04:34 AM
01typerboi
Dec 23, 2010 12:42 PM
civickiller
May 12, 2010 02:10 PM
Sprockets
May 26, 2005 07:32 AM
