part # on GM 3 bar Map
Old Sep 12, 2002 | 11:05 AM
revhardsi's Avatar
Default part # on GM 3 bar Map
I work at a Chevy dealer so I have like 10 map sensors in my box. I'm just curious to which one will see 15-18 psi. Not all of the maps are identical and 3 bar. I went to the hondata site and found no part #. I called them and they did not know. The parts guy here at work looked around and found one that is supposed to be on a turbocharged sunbird from the late 80's. On the parts catalog it said it's stamped 886. That is one that I have.
Any guys here run the GM map and can tell me the numbers on there map?
Old Sep 12, 2002 | 11:20 AM
The Punisher's Avatar
Default Re: part # on GM 3 bar Map (revhardsi)
I am interested this as well. I was told the GM 3 Bar was garbage and to go with the Electromotive one. Someone give up some part numbers please.
Old Sep 12, 2002 | 11:21 AM
DeepSi's Avatar
i believe the part # is 16040749 and i think you can go to
$49 @ http://www.gmpartsdirect.com
$60 @ http://www.turbo-link.com/tlink/order.html
hope that helps
-deepsi
[Modified by DeepSi, 1:14 PM 9/12/2002]
Old Sep 12, 2002 | 11:25 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: part # on GM 3 bar Map (gtr*lude)
http://www.Gmpartsdirect.com
these should be it:
gm 3 bar map sensor # 16040749 ($49.08)
harness: #12085502
Old Sep 12, 2002 | 11:45 AM
justagsr's Avatar
Default Re: part # on GM 3 bar Map (Arturbo)
these should be it:
harness: #12085502
Yeah Art, I think we already went over this a couple times and those are the right ones. lol Trial and error is what I always say...just not with my motor please.
Old Sep 13, 2002 | 05:32 AM
revhardsi's Avatar
Default Re: part # on GM 3 bar Map (justagsr)
thanks guys!!!!!!
Old Sep 13, 2002 | 06:17 AM
turboex's Avatar
is 16040749 the part number thats on the sensor? if not does any one know what number should be on the sensor its self? thanks
Old Sep 13, 2002 | 08:04 AM
revhardsi's Avatar
Default Re: part # on GM 3 bar Map (turboex)
that's a good question cause the parts guy looked some up for the turbo GM cars and they mostly said stamped 866. I'm assuming these are right unless they are only 2 bar.
Old Sep 13, 2002 | 08:30 AM
89civic1.8T's Avatar
So When I called and orderd my Map sensor I asked for on from an 87 Buick GN and I got a 2 bar map sensor just so you all know
Also what are the Delco #'s for these parts?
Old Sep 13, 2002 | 08:32 AM
turboex's Avatar
Default Re: part # on GM 3 bar Map (89civic1.8T)
yep i did the same thing. there are gm numbers on the side of it right
b18 hatch mike
Aug 29, 2008 09:33 PM
twkdCD595
Nov 30, 2007 08:06 AM
hondatm
Jan 19, 2007 05:31 PM
turboeg77
Feb 26, 2006 04:18 PM
philo
Dec 3, 2002 08:37 AM
