Painting Block? Head?
Old Jun 2, 2002 | 07:34 PM
2K_TEG's Avatar
Default Painting Block? Head?
I know this the wrong forum, but I have seen a couple painted motors lately. What did you use? How did you do it? How many coats? Etc.? Thanks in advance.
Old Jun 2, 2002 | 07:42 PM
int3gra's Avatar
Default Re: Painting Block? Head? (2K_TEG)
polish it! paint will probably flake off eventually. and if its a light color then it will get dirty fast..........yellow, white, milano red.
there is a guy on my block who powdercoats them for $40 - 50 Canadian
Old Jun 2, 2002 | 07:43 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
damn this 'paint your engine and tranny' is getting pretty popular all of a sudden? classic hotrod stuff though...just use engine enamel and make sure the parts are really free of oil and dirt and just spray several light coats.
Old Jun 2, 2002 | 07:51 PM
2K_TEG's Avatar
Default Re: Painting Block? Head? (not so civic)
I figured if it is out, might as well spend $25 bucks (I don't know how much paint costs) and make it look good too.
Old Jun 2, 2002 | 08:03 PM
trbob16a's Avatar
Paint costs like $3.50. Swing by wal-mart and get the ford red engine enamel, it looks pretty good. You can pick up silver also and do your whole motor if you want for another $3.50
Old Jun 2, 2002 | 08:06 PM
int3gra's Avatar
Default Re: Painting Block? Head? (trbob16a)
but u are adding more weight to your car by painting parts
Old Jun 2, 2002 | 08:10 PM
2K_TEG's Avatar
Default Re: Painting Block? Head? (int3gra)
I guess I should take that into account. I don't want to lose by 0.000020203802 seconds
Old Jun 2, 2002 | 08:49 PM
PrecisionH23a's Avatar
get high temp enamel paint, 1500 deg C is a good one to go with. walmart has them, i went with the aluminum color. Its a good idea to clean the block completely before painting, and after doing so take a wire brush adapter that will fit into your drill and brush the block up then clean up any residue with water. let dry, tape off then paint in LIGHT coats until you are happy, 3 or 4 usually does the trick. The only downfall to this is you cannot use simple green or any cleaners on it or it will eat the paint off. i havnt had any problems with it peeling off or chipping, but if you paint your block and tranny yellow... well then we will all kill you
here is my block after we painted it:
[Modified by GudeH23a, 12:50 AM 6/3/2002]
Old Jun 2, 2002 | 11:08 PM
intekragsr's Avatar
Default Re: Painting Block? Head? (GudeH23a)
Heres mine. I used that chevorlet red.
Old Jun 3, 2002 | 02:08 AM
dumbkid's Avatar
engine enamel spray is avalable at your local parts store ie. pep boys/autozone for about 3 bucks.
lude98SH
Paint and Body
Nov 26, 2007 08:32 AM
02vtecsir
Paint and Body
Apr 23, 2007 07:19 PM
delslo93
26
Feb 26, 2005 11:40 PM
cvcc
Mar 2, 2003 01:50 PM
BoostedB20A
Dec 22, 2002 08:11 AM
